Creep, Roll and Hold
Discussion in 'Model S' started by ADEEL421, Feb 9, 2021.
  1. ADEEL421
    ADEEL421 Member
    west palm beach
    So I had a loaner model 3 and I noticed it had a feature of "HOLD" under driving along side of creep and roll. see pic.
    How come we dont have this on our model S??? mine is a 2017 MS but only see creep and Roll.
    i loved how M3 would stop fully and i dont have to press the break however in my MS i have to press break for full stop and hold it there or the car does move.
    Also M3 slows down significantly when i release accelerator however my MS does not. i think it used to but now it doesnt break much.
    Anything I am missing?
  2. ucmndd
    ucmndd Well-Known Member
    Requires the PMSR drive unit in the Model 3 that your Model S doesn't have.
    • Informative x 3
  3. swt2c
    swt2c Member
    My MS will hold if you press and release the brake pedal after stopping.
    As for regen braking, what do you have your Controls > Driving > Regenerative Braking set to?
    • Disagree x 1
  4. Art_Vandelay
    Art_Vandelay Attractive Membrane
    Elon’s left eyebrow
    Considering Ravens (and probably Palladiums as well) have the front Permanent Magnet Motor, you can get a Raven (built on May 2019 onwards) @ADEEL421 and you can enjoy this feature as well as a vastly improved version of your current Model S suspension.
  5. drewr82
    drewr82 Member
    Denver
    My refresh ‘16 has hold as well.
    • Disagree x 2
  6. InspireSiR
    InspireSiR Member
    Rancho Palos Verdes, CA
    I have a 2021 Long Range Plus, which I just took delivery of, so I guess that would be a Raven.
    I just checked and I have Creep, Roll, and Hold options. I had it set to Creep as I thought I preferred the car to act like an automatic transmission. I will try Hold and see how I like it and how the regen works.
    On another note, I do not have an option to adjust the amount of regen when I let off the throttle. Was this feature removed with a recent software update or do the Ravens not have this feature available?
  7. ucmndd
    The brake hold feature on your car is not the same option that is being discussed here.
    • Disagree x 1
  8. dannycamps
    dannycamps Member
    Northeast USA
    Yes the ability to adjust the strength of the regen was removed from the Raven builds at the time the one-pedal driving (regen to hold) feature was added.
  9. f205v
    f205v Member
    Tessin, Switzerland
    @ADEEL421 I have a 2017 Model S as well.
    We are stuck with a motor technology that doesn't allow for "hold", because we have electromagnetic motors on our cars (both front and rear).
    Model 3/Y and newer Model S/X have electromagnetic motor on the rear, and permanent magnets motor on the front.
    The permanent magnets motor allows for the "hold" functionality.
    • Informative x 2
  10. ADEEL421
    ADEEL421 Member
    west palm beach
    Ahhh...this explains well. Thanks
  11. drewr82
    drewr82 Member
    Denver
    The OP references their personal vehicle as a ‘17 that does not have an option for hold. Thus, my comment about my ‘16 having brake hold is relevant.
    • Disagree x 2
  12. DukeofURL
    DukeofURL Member
    North NJ
    You are correct for the S, but the 3 is opposite, it has a PMSRM motor in the rear, and induction in the front.
  13. ucmndd
    No, it’s not. You’re talking about a different feature. Look at the menu screen shot in the first post. Now go try to find that setting with the same three options in your car. You won’t find it. Whatever you think your car has is not what’s being discussed in this thread.
    • Disagree x 1
  14. drewr82
    drewr82 Member
    Denver
    Ok, before you blow a gasket here, take a breath and relax. I should’ve chosen a different word, other than “option.” My apologies.
    I get it. Different drive units, different technologies, hence different features. You are referencing the menu screen of the Model 3. I am referencing this:
    In my car, at a full stop, I can release the brake because it switches to HOLD. This also what swt2c stated.
    • Disagree x 2
  15. jlv1
    jlv1 Twice as much fun
    Central MA
    Break HOLD is not the same as the Creep / Roll / Hold option being asked about in the OP. Your '16 does not have the feature being asked about.
    • Disagree x 1
  16. swt2c
    swt2c Member
    The reason I mentioned brake hold originally was because OP stated "in my MS i have to press break for full stop and hold it there or the car does move." which seems like the OP is unaware of the brake hold functionality.
  17. David29
    David29 Supporting Member
    DEDHAM, MA
    "Palladiums"??? Maybe I missed the memo, but what the heck is a Palladium?
  18. pilotSteve
    pilotSteve Active Member
    Prescott Az
    Yes, my 2016 S90D has this as well. Whoever “disagreed” with your post is not informed of the multiple iterations of brake boosters that have been shipped since 2012. Its not the same as current production but it “holds” the brake after manually coming to a stop. Its very handy and I love being able to hover my foot over the accelerator awaiting the green light.....
    • Disagree x 1
  19. Jughead135
    Jughead135 Member
    Georgia
    Let me try...: The part I bolded is where the confusion is coming in. No one is disputing that you have brake hold in the sense you describe.
    FULL STOP/NEW TOPIC: The question raised by the OP involves the distinction between older cars having "Creep" or "Roll" options (perhaps not called exactly that, I don't know), whereas the newer ones have "Creep," "Roll," and "Hold." The first two operate just like they did on the older cars. The third option allows the car to come to a complete stop on its own: regen down to whatever "min speed" is, then apply the brakes to come to the full stop (at which point, the "brake hold" you are discussing kicks in, as if the car had been braked manually to the full stop).
  20. Art_Vandelay
    Elon’s left eyebrow
