We are about to pick up a Tesla in Florida and drive it half way back across the country. Any tips for cross country driving? How to best use supercharging stations, etc? I looked for a cross country driving FAQ but didn't see one.
TIA!
TIA!
I agree with these statements....I just got back from a 6000 mile road trip from Florida out west and back. I used a better route planner to plan my trip because I wanted to go a different way from the way the onboard route planner suggested. I found that putting in smaller sections (say Jupiter, Fl to Mobile, Al) worked better for me. I also found that the onboard nav system was really accurate with percentage of charge left at destination. Be aware that the percentage at the beginning of your trip varies wildly and then "settles" as you get 50% completed...so don't worry if it looks like you won't make the next supercharger...I was never off by but a few percent at the completion. I used the AP-1 for 90% of my highway miles...found it was very relaxing. Of course i was always ready to take over, but very seldom ever needed to. Have fun.You can use A Better Routeplanner on pretty much any device and in the car to plan in advance and just get a general idea of the stops, etc.
When I'm actually on the trip, I usually just use the car's navigation and it's done a good job for me so far.
if your kit of adaptors that the car came with is intact you have the j1772 adaptor. as for what level to charge to your assumption of 10%+ is fine except when you will be encountering routes with long upgrades, severe headwinds, cold temps or rain/snow conditions, then you should consider getting an even higher buffer.Thanks for all the feedback and pointing me to those good articles. I do have a chargepoint account and keyfob card and I will check at the Tesla service center to make sure I have the right adapter for the chargepoint stations in case I need to charge at one of those. I used that better route app and let it plot the course and while I won't charge to 100% at each supercharger station I'll probably charge 5 or 10% beyond what the route app says at first, until I get comfortable with the results.
that assumption could be problematic if you encounter some of the conditions that I mentioned.I probably didn't state the buffer accurately, for example if the better route app says to charge to 70% to arrive with 10% then I will charge to 80% which theoretically means I should arrive with 20%.
there shouldn't be any issues with your going to 100% as long as you don't let the car remain at that level for a long period of time, charge to 100% as needed as long as you get going soon after hitting that level.I have a question......on my recent trip I stopped over night at several destination chargers (Hotels that provided free charging). I always reset my charging limit to 100% at these times, and started my journey the next morning with a full tank. Is this something I should re-think? Normal charging for me is set at 90%, or I charge to the suggested limit if Im on the highway and heading to another destination. Just curious if Im doing something wrong by getting a full charge over night?
I personally always charge with a 25 to 30 percent buffer in my Model S 85D. Never have any range anxiety even in adverse conditions.that assumption could be problematic if you encounter some of the conditions that I mentioned.
For example when I was driving west on I70 in kansas, which has a long steady upgrade for a few hundred miles, with temps around 15f with a 30+ mph headwind, which is normal there, fortunately I was forewarned by the people on TMC about the conditions there I would not have added a big buffer and I would probably not have been able to complete that hop, as an aside I wound up doing a lot of drafting along the way.
the bottom line is to be very aware of conditions ahead of you when on your long trip.
if that's what makes you feel good, I have no problem arriving at the SpC with less than 10 miles to spare, in fact it speeds the time necessary. In good driving conditions I rarely charge too far over what the trip planner recommends.I personally always charge with a 25 to 30 percent buffer in my Model S 85D. Never have any range anxiety even in adverse conditions.
