Cruise control defaults to 70mph
Discussion in 'Model X: Driving Dynamics' started by Merrill, Aug 13, 2016.
  1. Merrill
    Merrill Active Member
    Sonoma, California
    Wondering how I change the cruise control default speed, for some reason when I first turn on the system it defaults to 70 mph even if I have not gone over 65 on the last drive.
  2. Saghost
    Saghost Well-Known Member
    Delaware
    I'd think the easiest thing to do would be to pull the lever towards you and hold for a second, which should snap TACC to what the car thinks the current speed limit is (plus any offset set in the car's configuration page.)
  3. Merrill
    Sonoma, California
    Thanks, I will try that.
  4. phatteus
    phatteus Member
    NYC, USA
    Do you have the speed alert set? With mine at +14mph I always get cruise control default of speed limit +14.
  5. scottf200
    scottf200 Active Member
    Chicagoland ModelX S603
    Similarly I do +5 and see that. I wonder if you do absolute instead of relative it would do the same thing. i.e. if he has his set to absolute 70 mph.
  6. vandacca
    vandacca ReActive Member
    Hamilton
    I think they need to split out "speed alert" and "cruise speed". Right now, if I set speed alert to +10mph, it uses that to also set my TACC. Very annoying.
  7. Merrill
    Sonoma, California
    Yes, it is set at +5, so that must be the problem.
  8. Hookemhorns
    Hookemhorns Member
    Georgia
    Absolutely. I am always having to reduce the speed with some lever bumps after it automatically sets it to the speed limit plus my offset. The offset is for warning me, NOT how fast I want to drive normally. Really frustrating.
