Aside from taking up some room by their own thickness, most of the silicone cup holder inserts have bumps that are designed to hold smaller bottles and 12 oz. cans. While a naked M3/MY cup holder can accommodate larger bottles, I still would like to use something that lines the cup holders for easy clean up in case of spills or leaks. Another option I found is an insert between the cup holders that puts spring tension on the bottle. This might work fine for small and larger bottles, it does not line the cup holder to address the spills.
If you know of a cup holder insert that is less thick, has little or no bumps (or bumps that gives way when a larger bottle is inserted), please point the way. Thanks!
