Here is what I did to fix.
Went to Advanced Auto and purchased the duplicolor paint, spot bondo, 800 and 320 and grit sand paper.
I taped the rim where the rash started and ended so I wouldn’t go past. Then I sanded the rim with the 320 to get the rough part off.
Then I smeared some bondo on the rim being sure not to get on tire or other part of the rim.
Then I sanded with the 800 to smooth out.
Now came the fun part, painting. I applied the paint with the brush trying to be careful to not leave marks. Waited 30 mins then did another coat. If I had some rough spots I used 1200 wet/dry sand paper. After I was satisfied with the paint, I applied two coats of the clear.
Not perfect but much better and only cost me $30
