Current Model S weighs couple-hundred lbs less than earlier cars
Discussion in 'Model S: Driving Dynamics' started by andrewket, Jul 31, 2014.
  1. andrewket
    andrewket Well-Known Member
    From the Q2 financial results call. Elon just said said the current Model S weighs "several pounds" less than the original cars. Quarter pound here, half pound there.
  2. ChadS
    ChadS Last tank of gas: March 2009
    Redmond, WA
    Good to see them constantly improving. In another thread, somebody said it was 200lbs less?
    They originally had the reinforcements for the rear-facing seat in every car, that is now gone. That might have been in the vicinity of 50lbs.
  3. omarsultan
    omarsultan Active Member
    Northern California
    I also heard him say a couple of hundred pounds less...
  4. Cosmacelf
    Cosmacelf Well-Known Member
    San Diego
    Since the first Model S cars to now, the cars weighs a couple hundred pounds less according to Elon in the quarterly result conference call...
  5. andrewket
    Hey mods- would you please change the title?
    "Current Model S weighs several hundred pounds less than early cars"
    Thanks.
  6. Plug Me In
    Plug Me In Member
    Central Virginia
    Hey I want my hardware upgrade! Or is it downgrade?
  7. apacheguy
    apacheguy S Sig #255
    So Cal
    Does that mean the performance has improved as well? I'd like to see a Sig P85 go against a current (i.e. > 30,000 VIN) P85.
    Yeah, wouldn't that be nice.
  8. liuping
    liuping Active Member
    San Diego
    Between weight reduction and the improvements in charging efficiency, could they get a better MPGe rating now?
    How would that work since they done have a model year?
  9. trils0n
    trils0n 2013 P85
    SF Bay Area
    One part I remember hearing about in terms of weight reduction is the B pillars. I think the originals had high-strength boron-steel to beat more stringent European side impact intrusion tests. I heard they were redesigned to be all aluminum, stronger, cheaper, and easier to manufacture and that change saved 80lbs. Not sure if or when that design change made it into production, but 80 lbs is a lot.
  10. AnOutsider
    AnOutsider S532 # XS27
    Got it.
    With all these running changes, it should be impressive to see what the full 2.0 of Model S looks like from a performance and tech standpoint.
  11. NJ Plugin
    NJ Plugin Member
    When I got my car in June 2013, the car "sticker" showed a 89 MPGe rating. In January or February I was in a Tesla store and the sticker had 95 MPGe. I aksed one of the store personnel, and they had no idea why it had changed, or even noticed it.
  12. Dutchie
    Dutchie Active Member
    Canada
    They also had to add the titanium battery protector. This adds​ a couple of pounds..
  13. liuping
    San Diego
    I'll check my sticker when I get home, but I think is was still 89MPGe when I got mine in November. Maybe they changed it officially for the 2014 year...
  14. AmpedRealtor
    AmpedRealtor Well-Known Member
    Phoenix, AZ
    You were probably looking at a S60, which is rated at 95 MPGe.
  15. gavine
    gavine Petrol Head turned EV Enthusiast
    Philadelphia, PA
    Could I use a magnet to test if it's steel or aluminum?
  16. Lump
    Lump Active Member
    So. Cal.
    Saved 1 pound by making the hood thinner down by the latch :wink:
  17. Blurry_Eyed
    Blurry_Eyed MS Sig #267, MX Sig # 761
    Rear facing kid seats were redesigned, to my eye the materials they used for construction could have saved some weight in the cars that have the kid seats.
  18. Cosmacelf
    San Diego
    Elon and JB did talk about how the weight reduction didn't make the car all that much more efficient. I remember them saying that it was less than you'd think.
  19. Tasdevil
    Tasdevil Member
    Tasmania
    But it would save them in materials used to produce the car. $$ :)
  20. JRP3
    JRP3 Hyperactive Member
    Central New York
    So has anyone done a weight comparison? Have the official numbers changed?
