Custom fit trunk cooler
Discussion in 'Model 3: Interior & Exterior' started by Butane, Aug 20, 2018.
  1. Butane
    Butane Member
    Bloomington, IN
    Like others, I've tried to find a cooler that fits in the lower trunk as it's just such a convenient location for one. Since none of the ones I have fit and I haven't seen anything that makes optimal use of the volume, I decided the only reasonable choice was to build my own. :)
    This thread will be somewhat of a build thread. I'm learning lots of new things here, and with two little ones at home, I've learned to accept a more... leisurely pace with projects.
    In my head, this started out as just cutting and gluing some XPS foam boards together in the rough shape of the trunk. Test fitting wasn't all that great. I didn't like the boxiness of it and it just didn't look very good. Then I got some inspiration from folks who build custom fit subwoover enclosures out of fiberglass. I could do something similar. Nevermind my complete lack of fiberglass layup experience.
    OK, so several youtube videos and blogs later, I know I can put down a couple layers of tape in the trunk liner, some PVA release agent, and go to town. This will be the outer surface of the cooler.
    Since I'm going this far, might as well give the inner surface of the cooler the same shape as the outer surface. A true offset. Then it can be filled with expanding polyurethane foam for insulation.
    So what is the trunk shape? I decided to punt on trying to measure it manually and go with with photogrammetry to get the shape. Another new skill to learn!
    Here's my trunk with tape for contrast and an LED shop light above the vent:
    Here's the model in the rather excellent free version of 3DF Zephyr. Being completely new to this process, it was dead simple. The wizard produced great results on the first try, and it took very little tweaking to get something usable. I used my Canon 60D SLR with the 10-18mm EF-S and 28mm EF lens to take the photos. The software really wants you to use an SLR and common lenses as it pulls information from them to stitch the photos together.
    I imported the mesh into Fusion 360, my CAD software of choice, and got to work fitting spline patches to the mesh. I've never done anything but relatively simple parametric modeling in F360, so this was a new experience. I had a lot of issues getting the patch surfaces to merge into a solid body. I kept getting random compute errors and the process failing.
    Finished mold body
    The goal is to 3D print this and use it as a form to lay up fiberglass against. It will define the inner surface of the cooler, with the handles recessed into the sides.
    Sized to allow ~1.5" of foam to be poured between the fiberglass surfaces.
    Breaking it up for 3D printing. My printer has a 210x210x250mm build volume, so I have to slice it up for printing. Also adding holes for dowels to align the pieces.
    First 1 of the 16 segments was finished just as I was leaving for work today, and I should have another done late tonight. Looks like it's going to be around 150 hours of printing and nearly 3kg of filament, even with a 5% infill. Pics to come when I get home!
    What do you guys think? Am I in for any major headaches as I move forward? It's not like I'm attempting to repair flood salvage Model S or anything...
    • Like x 7
    • Love x 4
  2. Lasairfion
    Lasairfion Member
    UK
    This looks like a great little project. Photogrammetry is something I hadn't heard of before but seems to be a really easy way to get a 3D model like that.
    Is there a reason for using the 3D print as a form and fibreglassing the sides rather than just 3D printing the whole thing in plastic and slotting it in?
    I assume once done that you'll add a lid with a cooling motor and 12V DC power; or will you just go for a thick insulated top?
  3. Butane
    Butane Member
    Bloomington, IN
    Uh, I guess I kind of got fixated on using fiberglass. If I give it some thought, I see a couple issues with just printing. First the actual print would be huge, and take quite awhile. I'd have to print each section hollow and fill them individually with expanding foam and worry about the pressure on the thin plastic surface.
    I'd have surface finish quality issues too with the layers, but I'm mitigating that on the mold so that's a wash.
    Another is that the photogrammetry isn't perfect. There's a decent amount of noise in the image. Doing it again, I'd color the whole trunk in a light color and then use contrasting tape. The gaps in the tape showed up as height variances in the mesh model.
    If I can find a convenient source of 12V power in the back, I'll definitely look into a peltier cooler or similar. Otherwise just a thick top.
  4. Butane
    Butane Member
    Bloomington, IN
    Got a couple pieces printed now!
    I printed the piece with the handle the way because of printer dimensions. Rotating it so I don't need supports on the forming surface would require me to slice the mold on the long axis a 2nd time, creating another 6 pieces to print and more seams to smooth out later. The surface just has to be reasonably OK as I'll be sanding and smoothing with bondo anyway. Still, the flange has large texture patterns where the large gaps in support material created issues. Time to learn how to do variable infill densities in slic3r.
    Another issue that should have been obvious to me is that the handles are going to prevent me from cleanly pulling the fiberglass off the mold when cured. I guess I thought it would be flexible enough, but a friend at work disabused me of that thought. Especially since I may want to use the mold to ensure the fiberglass doesn't distort under the pressure of the foam as it exands. I came up with a plan to separate the handles, print them separately, and then secure them with bolts through the main body of mold. Then I can remove the bolts and pull out the mold from the fiberglass. If I put enough release agent on the seam, hopefully I can keep the resin from seeping in between.
    This turned out to be a pain in the ass in Fusion. Any F360 experts care to weigh in? The handles are formed on the body by lofting a sketch perpendicular to the face of the mold. I then combine the bodies together, and fillet the edges. To remove them, I tried creating a patch using the edges of the fillets against the main body and using that patch to slice the bodies apart. This gives me a compute failed error saying the cutting tool does not intersect the body to be cut. Variout efforts of extending the patch either roughly in plane or perpendicular failed the same way. However, if I go back in the timeline to before the fillets, this process works just fine. The problem then is I don't have a combined body to form the concave fillets against. Using a plane works fine, but I can't localize the cutting action to just the region of the handle; it cuts off the flange as well.
    Last issue is I should have bought a bigger nozzle. The default .4mm isn't really happy above 250um layer height and makes things slow.
    • Informative x 2
  5. PoitNarf
    PoitNarf The Clown Prince of Crime
    NJ
    Once you have a working prototype that fits well I’m sure you could find a manufacturer that could mass produce a bunch of these. I would definitely buy one if the price was right.
  6. Lake
    Lake Member
    Virginia
    I would buy this
  7. PTinetti
    PTinetti Member
    Denver, CO
    That is awesome
  8. Lasairfion
    Lasairfion Member
    UK
    Just as a note, if you want to easily smooth your 3D prints, I did see a video on using an acetone vapour bath:
  9. Nocturnal
    Nocturnal Member
    Kansas City
    Nice idea!
  10. Butane
    Butane Member
    Bloomington, IN
    Thanks, that's a good idea. Unfortunately that only works with abs, which I didn't have enough experience with to be sure I could keep it from warping. Either way I'll still have seams between each of the pieces, so I'll need to fill and sand those anyway.
    In the meantime, I'm getting serious surface quality issues on the flat parts and wall collaping due to low infill so I'm experimenting a bit. Slic3r has a cool new infill called gyroid that was my new default due to its equal strength in all directions but it turns out it delaminates easily at really low infill percentage (5%). I'm also getting a bigger nozzle to speed up printing and provide more wall strength. Turns out 3d printing large objects is a bit different than my usual trinkets and toys.
  11. stonelance
    stonelance Member
    Seattle
    This looks neat. I've never done anything like this before, but couldn't you just line the cavity in the trunk and fill it with some sort of expanding foam and then use that as the mold\template instead?
  12. Butane
    Butane Member
    Bloomington, IN
    Possibly. The problem is how to control the depth of the foam. I brainstormed this with a composites engineer (who thinks I'm nuts) at work and he suggested adhering a bunch of small wooden dowels as depth gauges to fiberglass and then cutting/sanding the foam back until I find them. This could work, but would be labor intensive and tedious. However, the crucial problem with that approach is it doesn't give me an excuse to do the photogrammetry, learn how to work with surface patches in Fusion 360, 3D print obscenely large objects, or make fiberglass molds. Along with with failing at each step repeatedly. :D
  13. stonelance
    stonelance Member
    Seattle
    Yeah, I get it. I love learning opportunity projects as well. Unless they were projects I wasn't planning on being learning opportunities :)
  14. getto
    getto Member
    me too :cool:
  15. Jimmy 1
    Jimmy 1 Member
    Tallahassee, FL
    Curious, If this could be mass produced, what would be the cost?
  16. EVnut
    EVnut EV #5
    Davis, CA
    This is great! Hows the project coming along?
    In the meantime.... can somebody figure out how to make a flexible, custom-fit liner for that same space? Just like this cooler, but thing-wall and not rigid. I mean now that you have it all mapped out...
    How about a plastic sub-trunk liner/carrier?
  17. Emmexx1
    Emmexx1 Member
    IL
    This would be awesome as it is the main place I keep all my stuff and would like to keep winter shovel and brush, but don't want it messing up the carpet there. I have the Tesla trunk and frunk mats, but nothing below :(
  18. Butane
    Butane Member
    Bloomington, IN
    I had a project? Oh shi..... :eek:
    I've made little progress even by my poor standards. I printed a bunch of parts, and noticed how the curves are pretty terrible as can be seen in the images above. I really started to run into the limits of my CAD skills to fix it. Then between kids, getting really busy at work, traveling a lot, family events, and lack of sleep, I have shamefully stared at my work with promises to myself unfulfilled. But I'll get there! :D
    Quick possible solution for your idea- Tape plastic sheeting to fit the trunk, (maybe?) apply a mold release agent, and then spray on either plastidip or that spray rubber sealant stuff. Build up a bunch of layers and peel off the plastic. I may try this as it would allow me to procrastinate on my project that started this thread!
  19. EVnut
    EVnut EV #5
    Davis, CA
    This sounds like a fabulous idea! :) Glad to have you back.
  20. longshot49
    longshot49 Member
    Montreal
    I would also buy one!
