  • The final cut of the 8th episode of the Tesla Motors Club Podcast, featuring Balazs Biro, of the prominent Hungarian EV channel Villanyautósok, is now available. You can watch it now on YouTube or listen to it on all major podcast networks.
Custom Plates on a Tesla
Can anyone share their experience with custom plates on a Tesla. I’ve got a white Model 3 coming in a few weeks time and trying to decide on either black on white or white on black for the plates.
A little worried white text on a black plate might look too out of place on a white car and wouldn’t go with the aesthetics of a white M3.
Has anyone here gone this option or any custom plate colours/ styles and can share their experience and some photos?
thanks
smartypnz
2,324
2,517
Monterey Peninsula
thanks
Add Glitter
Reactions: Leeroy and Hairyman
thanks
White on white wont look great unless the whites are identical, which they probably wouldn’t be. There is also lots of black features on a white car.
Stromi
Model 3 SR+
Oct 17, 2019
26
21
Awstralia
White on black.
A suggestion: select a smaller euro style plate for the rear rather than a standard size plate.
The plastic plate holder can allow the larger plate on the rear to bounce or flap,
especially when closing the tail gate.
I lost the plexiglass Tesla plate frame and after it was replaced by Tesla Service,
I investigated the problem. When the plate was originally affixed to the plate holder, (by Tesla)
the screw that holds the plate on the left hand was overtightened and the plastic boss the screw
engages had burst so the screw no longer attached the plate firmly allowing the plate to flap.
I repaired it with JB Weld: apply JB Weld, apply radial squeeze with small ring clamp,
when JB Weld almost set, carefully remove ring clamp and replace with zip tie.
Zip tie the other side for good measure.
The plate was still a bit loose so I added double sided adhesive pads to the bottom
of the plate so that it was attached to the bottom of the plate holder.
Finally I bent up two strips of thin aluminium sheet into clips that hold the plate cover securely.
Reactions: Hairyman
meloccom
Moderator Aus/NZ
Moderator
Feb 11, 2008
2,611
1,659
Sydney Australia
Did you get the Tesla service centre to put your custom plates on during pick up? Or did you swap them out after pick up?
Also, does anyone know if there are any issues with shorter custom plates e.g. 254 (h) x 134 (w)?
If you don’t want holes drilled into your plates, do it yourself. Only use automotive grade double sided tape available from automotive stores like Repco or Supercheap.
Reactions: paulp
Tesla arrange the transport company to supply and install the plates/rego process. Hence if you dont mind some transport guy screwing your plates on crooked with screws that rust, then let them do it. Not sure which model you are applying your plates to. If S the smaller plates will be fairly borderline in covering the existing rear screw points.
Hi all
Thanks for the replies, it is a Model 3.
Provided the plates come in time I will get the Tesla service centre to put them on.
The below images are an example of the plate sizes from the myplates website - so finger crossed the Tesla service centre does not use the far points to screw in the standard plates --> Time to talk to the sales staff :)
