Custom Socket Tool for Refresh Front Plate License Screws
Discussion in 'Model S: Interior & Exterior' started by James Anders, Jun 18, 2016.
  1. James Anders
    James Anders Member
    Southampton, PA
    So, thanks to Btrflyl8e who was gracious enough to send me a sample screw, I've designed simple little socket adapter that will remove these screws. The socket design has a recess for the wacko 5-lobed security screw and a 1/4 inch recess on the other side that will fit onto a 1/4 inch drive ratchet or Allen wrench or nut driver. I tried to keep it small, simple and affordable.
    It's currently being 3D printed by Shapeways.com out of stainless steel. I'm getting one in about a week or test and if it passes muster I'll offer it up for sale on Shapeways. Not looking to really make a profit on this. I just want to provide a service to the community. And because I think these screws are stupid. I will keep everyone posted.
    -Jim
    • Like x 7
  2. SteveW25561
    SteveW25561 Member
    Vancouver, Canada
    That looks great, Jim. Would you be willing to share the file so people can try on their own 3D printers at home? While you'd obviously want a metal tool, the reports seem to indicate the bolts are not torqued in very tightly and it'd be interesting to see if a home printed plastic tool would work (perhaps with 100% infill).
    Totally understand if you'd rather keep the file to,yourself given the effort but I thought I'd ask.
  3. Larry
    Larry Member
    East Bay of SF
    Thanks for doing this. Put me on the list to purchase as soon as it becomes available.
  4. Vitold
    Vitold Active Member
    NM
  5. James Anders
    James Anders Member
    Southampton, PA
  6. ColBatGuano
    ColBatGuano Member
    Texas
    If I may ask, what is the diameter of a circumscribed circle around the outside of the lobes?
  7. Marvin Somlo
    Marvin Somlo New Member
    chicago
    Please let me know when I can also get one of these,
  8. James Anders
    James Anders Member
    Southampton, PA
    I have no problem sharing the file once I receive my first piece and test it. I'd rather not give out the file until I'm sure it works as I believe it will.
  9. bobjustbob
    bobjustbob Elon Musk takes all my money
    Cumming, GA
    Hopefully this works. I'm wanting to remove my front plate holder but I want to make sure I remove it in a non-destructive way.
  10. NikeWings
    NikeWings Active Member
  11. jelloslug
    jelloslug Active Member
    Greenville, SC
    In for later!
  12. NikeWings
    Honestly, the bracket screws are the easy part. The gunk holding the bracket to the nose has the potential to cause the destruction as the adhesive is quite thick and strong, and is glued along the entire length of the plate as well as 25% down each side.
  13. FlatSix911
    FlatSix911 Porsche 918 Hybrid
    Silicon Valley
  14. ZeroDarkSilver
    ZeroDarkSilver HEPA cleaning your atmosphere, you're welcome
    Northern California
    Not sure why people are still going down blind alleys (gator grip) and custom fabricating tools for this...it's much, much simpler than that:
    Definitive S Refresh Front Plate Bracket Removal
    In fact, if I could amend my original post I would add that you could probably unscrew the security bolts using just your fingers; they are not torqued very tightly at all.
  15. NikeWings
    ZDS........I too used the same pliers for 2 simple turns and easily unscrewed them off with my fingers. The glue however took a little maneuvering with a string to cut through it and release the plate bracket from the nose.
  16. James Anders
    James Anders Member
    Southampton, PA
    I've completed the socket and it's available for sale on my Shapeways site.
    Tesla License Plate Socket Adapter by SlippinJimmie on Shapeways
    There are two versions. Stainless for $14 and Plastic for $4. Some people have said their screws were really loosely torqued so the plastic MIGHT be fine. But I'm not guaranteeing that. The stainless version should handle even the more tightly torqued screws. All you need is a 1/4" Allen wrench to slip the socket onto.
  17. James Anders
    James Anders Member
    Southampton, PA
    By the way, I was not able to remove my screws by hand. Just too tight and it's tough getting one's fingers around the head because of the recessed plastic which shrouds the screw heads.
  18. AltPowr
    AltPowr Member
    Moorpark, CA
    Ordered - thanks! Preparing for my P100D when I order it.
  19. Frankman60
    Frankman60 Member
    San Diego, CA
    I ordered this adapter in stainless steel and used it last weekend on my new MS60. I erroneously thought that it would fit on a socket wrench, but after closer inspection I found that it fits on a 1/4 inch Allen wrench which I didn't have available. Fortunately I was able to borrow one from one of my neighbors and it worked great. I bought the adapter because I did not want to damage the bolts trying to remove them just in case I need to put the plate back on in the future.
  20. James Anders
    James Anders Member
    Southampton, PA
