TEG:
Umm, Hello!, how about we duct the motor heat output and use it to prime the cabin heat? ICE cars use waste engine heat to heat the cabin, so why not save the traction pack charge and recapture "waste heat". Does the current design just send the eMotor heat into the atmosphere without recapture?
In case you are not being sarcastic, here is an answer.
"Trouble" is, that "waste heat" is being generated "only" when the motor is rotating i.e. the car is moving. The faster it moves, the more power it is using and more waste heat is being generated. When you stop, no waste heat alas no heat for you. When you are going downhill with no power to the motor - no heat for you.
In the morning, when you sit into your cold car and slowly back off out of your garage - sorry, no heat for you.
Additionaly, The Roadster has and will have aircooled motor. Air keeps very low amounts of heat so you cannot store warm air on-board for occasions when you'll need it. So yes, the waste heat is sent into the athmosphere. As much and as quick as possible to keep the motor as cold as possible. The eMotor does not need to warm up as ICEs do, to function properly. Actually the colder it is, better it will function (more efficient).
As for WhiteStar if indeed it gets liquid cooling I guess they will use that trapped heat for heating the cabin just as in an ordinary ICE car. Additional electric heater will probably be added for faster cabin heat-ups.
Michael:
... almost no excess heat ...
That means very low power and very slow response and very low torque and very low max rpm. Do you want 100 or 1 kW car? I'd say that quote is pure marketing b*llsh*t or something was lost in translation.
80% - 90% efficiency is very darn close to best possible that still makes sense. If we decrease losses tenfold, we only increase efficiency by 10%. Are you sure its worth it?
