Cybertruck as mobile powerwall
Discussion in 'Cybertruck: Battery & Charging' started by winfield100, Jan 23, 2020.
  1. winfield100
    winfield100 Supporting Member
    vivant non-traveler
    Are there folks considering using the cybertruck as a stationary/mobile set of powerwalls?
    My initial thoughts were the 75 kW is actually ~5 powerwalls plus a basic truck that I could combine with my 11,655 PV array.
    Legally I cannot disconnect from the grid, but hurricane Irma caused >5 days no electric.
    My minimum electric bill is $21.69
    If I buy electricity at night it’s 8.9cents per kWh
    If I sell the same electricity it’s 2.585cents per kWh
    I make ~190% of my needs
    I also see the CT as a potential node in a Virtual Power Plant with my PV
  2. ewoodrick
    ewoodrick Well-Known Member
    Buford, GA
    Sure you can consider it. Doesn't mean that it will do what you want.
    • Disagree x 1
  3. johnm6875
    johnm6875 Member
    Auburn
    In my perfect world I'll be able to buy/install the switch/monitoring unit for my house that Tesla uses with the Powerwall as a separate component and plug my Cybertruck into that. I'll be able to "load shift" and provide backup power from an over 100kWh+ battery (while using my solar). In a few years this set up would pay for the installation costs and provide days of quiet non-polluting power.
  4. bkp_duke
    bkp_duke Active Member
    San Diego, CA
    The cybertruk will have limited output on the 240V, etc. Basically whatever the AC to DC inverter will allow (that's 48A in the current 3/S/X). It will be ideal for emergency backup, i.e. hooking a refrigerator into, etc. but Tesla is not going to give you enough output to hook your entire home, or even a substantial fraction of the home, into the truck.
    I've got $5 that says if Tesla does allow this, that they won't give you access to that full 48A either. That would put undue stress on the inverter, increasing the number of failures in warranty, etc.
  5. winfield100
    vivant non-traveler
    And yet, the smallest version of the Cybertruck has ~1/2 of a power pack (>5 powerwalls equivalent)
  6. bkp_duke
    San Diego, CA
    It's not the amount of power in the pack, it's the RATE at which you can access it.
    My P85 has 2X the power that my 3 powerwalls have, but Tesla doesn't install the hardware in the car to allow for pack-back-to-grid.
    They will have that hardware, in a limited sense in the Cybertruk, but it's not capable of the RATE of power output (measured in AMPs or KW - take your pick) that you would need to run a house from.
    Also, do you know the thickness of copper cable that would be required for that? Go look at your house's main wiring input. It will be a thick cable capable of 100A (older homes) or 200A continuous input. It's like 3/4" of an inch thick per line (and there are multiple).
  7. Uncle Paul
    Uncle Paul Well-Known Member
    Canyon Lake,CA
    Imagine that this will come in the future. Lots of people working on it, but not as easy (or safe) as people might hope.
  8. winfield100
    vivant non-traveler
    @bkp_duke
    Did you even understand the original premise?
    Part is “node in a VPP”
    I wasn’t clear also in original post
    Not saying “run the whole house” obviously.
    You have your PV array and 3 powerwalls and should be full aware
  9. bkp_duke
    San Diego, CA
    You are correct, you are were not clear you wanted to be a node in a virtual power plant.
    This, however, is regulated by your specific power company. I don't know about FL, but here in CA I'm prohibited from selling power back to the grid from my powerwalls (I can only do it on solar). Here at least, they do monitor and know if I export back in the evenings.
    It's stupid, doesn't make sense, but it is regulated, so just make sure you follow the regulations for your power company.
    Basically, you want to "rate arbitrage" with the pack on the truk. That's fine, but it's not as simple as having the freedom to "do what you want". You may own the truk, but they own the grid and determine the rules for it's usage.
  10. winfield100
    vivant non-traveler
    @bkp_duke
    Actually,
    I was very clear, it’s the last line in the comment about VPP’s
    At the moment the “rate arbitrage” goes against me
    Since my PTO, I export about 8,500kwh during the day to LCEC, at 2.585cents per kWh
    At nights, I bought the same or similar electrons back at 8.9cents per kWh, about 3,000 - 3,500 (no excess check yet)
    So I need about 10kwh per day, at night, eh. (More in summer)(but shorter nights)
    Presently, “behind the meter” isn’t regulated
  11. Uncle Paul
    Canyon Lake,CA
    Reminds me of earlier Nordic posts. One guy mounted high powered lights over his solar panels. He would turn them on in the evenings when electric prices were near zero, to charge his batteries. Made economic sense...for his individual condition. People are clever...but goofy.
  12. bkp_duke
    San Diego, CA
    Yeah, you weren't clear, and I'm sure others read the same that I did. But I understand your premise now.
    Here, behind the meter is STILL regulated. If you are not in FL, then that is fortunate. I know the one time I exported to the grid after the sun went down I got a notice from SDG&E, they didn't like that. I can, however, use from my powerwalls to my heart's content and they cannot say anything.
    EDIT - my initial point still stands. You won't be able to run large things like AC units from the cybertruk. It won't have a high enough amperage output to do that. That will limit how much you can arbitrage from the pack in the truk.
  13. Morgantown
    Morgantown New Member
    Morgantown, WV
    You ought to check out the Jack Rickard video on Youtube. He discusses using the 240v plug of the truck to back feed as back up for a house. All depends on the software limitations imposed. Do a search on youtube: Cybertruc +rickard. It is entertaining albeit long. It is the second video released on the truck, not the first.
  14. winfield100
    vivant non-traveler
    @Morgantown
    Thank you.
    (;is that the EVTV? I listen .to jack at 2x speed with captions and it sounds normal speed
  15. Morgantown
    Morgantown, WV
    Yes sir, lol.
  16. SeminoleFSU
    SeminoleFSU Voluntaryist
    Atlanta, GA
    Agreed. Jack says the CT will most likely use the inverter/charger combo that's in the M3/MY. IIRC, it's 10kW. Which would definitely allow a full 50A @240V... This would be a nice way to backfeed our homes (with an interlock for safety) and run critical (not all loads but critical loads) in your house in a pinch. Great for brief (few days) power outages. C'mon Tesla! Please let us do this!
  17. Teddys
    Teddys New Member
    Aireys Inlet, Victoria, Australia
  18. Teddys
    Teddys New Member
    In Australia I live in a coastal region with bush fire risk. When a bush fire rages power lines go down. We do have back up power but it is old. Far simpler to have electric backup. My wish is that Tesla would allow and even fit the capability to each and every vehicle to be used in an emergency - ie not for everyday use. Could also assist in being able to give another Tesla a bit of a helping charge if necessary.
  19. ra88it
    ra88it Member
    Southland
    Many reports have shown that V2G/V2H has been built into recent model 3s... it does make you wonder if they’re testing products with the recent release of the new WiFi charger that has the ability for software updates.
  20. Atari2600
    Atari2600 Active Member
    Cincinnati
    I hope it is considered a home solar battery and qualifies the cybertruck for a 22% tax credit in 2021. Wouldn't that make a lot of people mad? It may just even out the bad karma for the Hummer tax breaks back in the day.
