So i have a reservation on the Cyber truck and we are finishing our basement. What kind of power should I run to prepare? The cost of running it now will be a lot less than if the basement is finished. What should i run: 2/3/4 or 8 gauge wire? Size of circuit breaker (in amps)? receptacle at the end (NEMA 14-50)?
It all depends on how much power you have in your house and how much you want to spend. At minimum, I would run 4ga (assuming romex) to allow up to 60a if eventually needed. Either leave it unterminated / unconnected or put a 14-50 and 50a breaker. If you want to go all out put a 100a sub-panel in the garage.
My electrician ran 6ga wire for my 14-50 to a 50amp, but perhaps the shorter 20 foot distance is the reason for the thinner cable. If you leave it unterminated and use it to hook to a Wall Connector directly you can save 1/3rd of the money by running two not three conductors plus ground. Perhaps the best bet is just to run conduit and pull a string thru it so that later you can pull WHATEVER you decide. I just helped a friend do that in his new house, It was super easy to just tie the romex to the string and then tug it thru and hook it up to a breaker that we also bought and wire it into the Wall Connector.
It only comes with one 14-50 but it's easy to swap out. Plenty of space. Siemens TL137US Talon Temporary Power Outlet Panel with a 20, 30, and 50-Amp Receptacle Installed, Unmetered
Yeah, 100A to the garage. However, if you can do 200A and separate meter to the garage, that's even better. Not specifically for the Cybertruck, but for future proofing BEVs in general.
At my friends house we tapped a 200A line directly off his main bus. Kind of a special circumstance since the run was ~200' so we were going to run 4/0 Aluminum triplex anyway... tapping off the main bus eliminated the need for installing another breaker. I still can't get >60A charging at his house because he has #6 feeding his service and the utility insists that's 'adequate'
I would do thicker wire, in the scope of building a house the cost of a little thicker wire is nothing. The CT has the potential to be very hungry if used as a truck, you wont regret having capacity to feed it whatever it can take, plus EVs are only becoming more common amd eventually the garage will likly house more than one. The "conventional wisdom" about sizing the charging solution for daily needs to short sighted. What happens when you buy a fishing boat and want to travel to two different lakes on the weekend, will a minimum connection recover Saturday night so you have no worries towing again Sunday?
I would also consider the potential for v2h with the CT powering your home. Not sure if it will happen but you should plan for as much amperage as possible across that cable.
Ha! Yeah, I'm an idiot! I guess I could have saved even more money if I had thought about it. But it was pretty cheap, $66 for 50 feet and we didn't have to deal with undoing three spools of wire as I pulled it thru. Please don't tell me it would have only been $12 in wire, actually I know it would have been more as I did my solar in spools of wire and that wasn't cheap.
@Feathermerchan So you would argue against overkill even at time of construction? I think one detail folks are overlooking is that miles added per hour is going to be lower in the CT than everything else given the same supply. A 60amp wall connector is rated at 44mph for a 3 but only 30 for an X the CT is sure to consume more than the X even without towing or the like. I would spend an extra $100 on thicker wire now, vs. paying for supercharging and have to supercharge on busy weekends
I really don't feel like pulling into a supercharger if I don't have to. For me it would be a 75 mile addition to go to that point to charge for one of my frequent trips after mapping it out. Not a big deal, but who knows where charging is going at home. I would just imagine more in the future if more people are considering electric cars and other electric devices to replace combustion engines. So I would go with the thicker wire. When I put my garage service in I had one Tesla. Now it will be 3 plus the Airstream. Glad I planned ahead. Just have to plug the truck in outside. @nwdiver That RV box is where the spiders always hang out. Nightmares.
2 or 3 gauge, 60 A breaker, NEMA 14-50 That said, I am not sure that there will be enough space for CT in my garage, so I start thinking how I charge it on my driveway.... You are a lucky man if you are going to have enough space in your basement for a CT! I am not concerned on the charging speed based on my M3 experience. At 30m/hour it is very adequate, usually charging for 3-4 hours 2-3 times a week. This should leave enough time for CT charging. Even if the charging rate is only 15 miles/hour, it will be enough to add 200+ miles overnight enough for several days of typical driving. My main question is about the waterproofing level of the standard charging cable/port. Would I be able to leave it plugged in and charging during a stormy night? Did anyone have experience charging outside in heavy rain?
I only charge outside and it's very safe. The Wall Connector is weathertight and mounts just fine on a post outside (although I just run my cable under the door of the garage). There are sensors to be sure ground is cleanly connected and the voltages are tested before they are connected to the car. There is a latch that refuses to allow the cable to disconnected before the power is turned off.
