Cybertruck in sub. -30C temperatures
Discussion in 'Cybertruck' started by Nordah, Nov 23, 2019.
  1. Nordah
    Nordah New Member
    Finland
    Is there any knowledge on possibility of leaving truck in cold temperatures? 200kw capasity should make this possible, and truck use in the north would reguire this. I ordered, but I'll need to sort this out before final desicion.
  2. Revelation
    Revelation Member
    North Carolina
    The better question to ask is what effect temperatures will have on the new battery tech that Tesla is working on.
    I cannot imagine them rolling out a Cybertruck with existing tech to meet the stated specs.
  3. S'toon
    S'toon Knows where his towel is
    AB
    #3 S'toon, Nov 23, 2019
    • Helpful x 2
  4. OConnorStP
    OConnorStP Member
    Praag, WI, USA
    -30 is just plain miserable and cars/trucks feel the same way. That said, it's a lot easier to start my Tesla than it is to start the diesel tractors in the morning. Range takes a hit and at -30 I'd probably count on about 50% when doing travel planning if starting from dead cold. The outbound trip is helped a lot by preconditioning the battery. And here's a tip if you have a Performance version -- Ludicrous Plus has "Max Battery Power" which heats the battery somewhere above 40C. I get "springtime" range when I start out that way. But returning home after a full day of cooling off? Still miserable.
    • Informative x 3
  5. SSedan
    SSedan Active Member
    Greenville Wisconsin
    I have a 2014 S. Heating battery to ludicrous mode temps to cope with cold is a foolish waste of energy, the only purpose it might serve would be staying warmer once parked. I think running some preheating partway thru the day would work a lot better to hold off a full cold soak.
    Pack takes time to reach ambient temperature, preheating while plugged in helps offset what some have coined the "departure tax".
    I have parked my at work at -20f at work which is pretty close to -30c and by the time I left had the temp all the way up to -18c, it will double or triple energy use for the first few miles but it handles it.
    I wouldn't go leaving it at the airport for days at -30c not plugged in but for a shift at work is fine in my experience with the S.
  6. ricohman
    ricohman Member
    Saskatchewan
    We had a solid month last year where the temp never rose above -30.
    Plan your trips accordingly.
  7. S'toon
    AB
    Just like the winter of '97. How I remember that year.
    So, there I was, crossing the street by Midtown plaza. Guy tried to run a red light, had to brake hard to avoid hitting pedestrians crossing with the light. He rolls down the window, -30something, and starts swearing at them, as if it was their fault he had to brake. And then, he turns, and starts swearing at me!
    • Funny x 2
  8. Xminus6
    Xminus6 Member
    Bay Area, CA
    I would also definitely recommend against licking the body panels of your Cybertruck at those temperatures.
    • Funny x 7
  9. ItsNotAboutTheMoney
    ItsNotAboutTheMoney Well-Known Member
    Maine
    Just need to plan one trip, starting from Here, ending in The Hell Out Of Here.
    • Funny x 3
  10. M_D129
    M_D129 Member
    Minnesota
    Would be great if they offered a battery heater option, instead of just relying on waste heat. Reduced regen on a CT, would put some serious load on those brakes.
  11. mongo
    mongo Well-Known Member
    Michigan
    The new drive units can operate in an inefficient heating mode, even which stationary. Same net result as the original S/X inline heater.
  12. Big Earl
    Big Earl bnkwupt
    Springfield, VA
    Better end result, as it’s variable and can produce up to 7 kW of heat for the battery pack. :)
  13. Nordah
    Nordah New Member
    Finland
    I'm wondering if its possible to make 3 days weekend trip to hunting cabin without electricity on those conditions?
  14. bpjod
    bpjod Supporting Member
    Alberta, Canada
    I'm more concerned about how the rear bed cover is going to hold up in winter. The button to operate it faces upward. Will freezing rain or melting snow get in there and freeze damaging the mechanism? Will snow on the cover get pulled into where the cover is stored when you open it and cause damage?
  15. Laserbrain
    Laserbrain Member
    Germany
    I wonder what happens when you touch the Cybertruck's steel body with bare hands in sub -30°C temperatures... instant frostbite?
  16. EnrgyNDpndnce
    EnrgyNDpndnce Member
    Charleston, SC
    Reading this thread makes me thank the Lord above I live in Georgia!
    • Funny x 2
  17. Saghost
    Saghost Well-Known Member
    Delaware
    Not instant, unless your fingers are wet. In which case they are also now frozen to the body shell.
  18. SSedan
    Brakes will be capable without regen, would be wildly irresponsible to figure regen into safely stopping a load.
    That said pack will warm quickly towing.
  19. M_D129
    M_D129 Member
    Minnesota
    Yeah, I know they’d put robust brakes in, I just hate using brakes anytime now, haha. Any amount I have to use them I feel like I’m “chewing” through them. Term used lightly in this context.
    That said, agree that towing will definitely heat up pack very nicely!
  20. M_D129
    M_D129 Member
    Minnesota
    Very good points from you and Mongo. I stand corrected! :)
