mspohr
Great to see the laminar flow over the roof and down the back as well as the high sides improving flow. Could be quite good overall.Saw this on Twitter, so do not have a link to original FB source...
Thanks for the thoughtful reply. The reality is that faceted surfaces are terrible for aerodynamic efficiency. Do you know why the F-117 Nighthawk is faceted? Because, at the time, we couldn't figure out how else to reduce radar profile of more efficient aerodynamic surfaces. The F-117 was (and is) an "unstable" aircraft because of its shape.
But whatever - it's a Tesla . . .
Reading this thread and it was the second page to see someone comment correctly that it is a function of the materials. The design is amazing partly because of the materials, no forming or pressing this stainless. Also, no paint shop (huge huge cost savings).This is actually incorrect. there are only hard angles on this as that's a limitation to keep the 30x cold rolled Stainless Steel from becoming cost prohibitive and this combined with as someone else has pointed out is the optimal aero shape ( Streamlined body/half body) approximated with a flat faceted surface is a compromise of aero efficiency for weight/durability. The F-117 is unstable has it has to manage that on many planes not flat on the ground like a truck.
The Motortrend report sheds some light on this:
" Tesla might have erased the problem with active suction to bend the boundary-layer downward just aft of that peak. Gordon Murray's McLaren F1 used this trick, and SpaceX has plenty of expertise in active measures to manipulate airflow around its re-entering Falcon 9 first stages. However, with the bed cover deployed, the angle of its vast descending surface is evidently shallow enough for the flow to naturally reattach. The benefit being that it harvests a useful fraction of the air pressure that blocky, open-bed trucks almost entirely forfeit. Actually, the tougher aerodynamic trick has been coaxing the temperamental flow around those sharp A-pillars."
Seems to me that the design is very well thought out. Now can they get the govt to approve camera's instead of mirrors. One would hope so because mirrors are just not useful in today's world. Where is the bumper? What will actual lights look like? Lots of small stuff but the truck has a very very interesting design and it shows enourrmass innovation. I still wished it did not look as uglyI think you're being a bit too exact with my video.
1) even in the video the separation is minimal compared to similarly sized conventional pickups
2) my video is not a complete 3 dimensional analysis of the truck it's a polygon in the rough profile shape I drew up and uploaded to a modelling web app ( as well the underside is completely imagines as we have no pictures of that) you can even see the white triangles outside the profile interacting with the flow so this may show a more negative flow than reality
3) As I mentioned before this may be offset by the overall lower drag coefficient of a bare stainless steel vs painted surface as there is an improvement there
In any event the primary design decision here wasn't around aerodynamics although it was ( and is always ) PART of the consideration it was around limitations of the material
The Model S is insanely aerodynamic and also looks amazing. Is it too much to ask for something that looks amazing and performs well? I thought that was kind of Tesla's whole thing but now I see that they're almost entirely abandoning the virtues they previously held important.
So now that your premise has been proven wrong will you admit it? And request a change to the thread title to reflect reality?
I don't believe anyone said it would beat the S or X in aerodynamics, just that it was actually pretty good and phenomenal for a truck.You should find something more productive to do . . . Perhaps when the Cybertruck specs are posted you can be in a position to run your mouth. Right now - I'm not so sure.
That would be about right for unplugged, but plugged in, mine (2013 85) charges back up to the set point every other day.Aerodynamics of the Cybertruck need to be compared with all other similarly sized trucks on the market.
For those overly concerned about wasting energy, attempt to use a more aerodynamically designed EV each time you haul stuff.
Take into consideration the phantom/maintenance loss of energy by not using an additional EV if you have more than one. My 2012 MS P85 would use about 80 kWh a month when left plugged in and unused. Perhaps newer models are more efficient when left garaged.
Using the ChargePoint Home EVSE, they send a monthly report of usage. The 2012 MS P85 was charging daily as needed for that approximate 80 kWh per month. Some months were higher if doors were opened or tires filled with air, but I was only including the months of complete non-use.That would be about right for unplugged, but plugged in, mine (2013 85) charges back up to the set point every other day.
Ah, I thought you meant that it lost 80 kWh in a month and was almost empty. Using 80 kWh in a month sounds about right.Using the ChargePoint Home EVSE, they send a monthly report of usage. The 2012 MS P85 was charging daily as needed for that approximate 80 kWh per month. Some months were higher, but I was only viewing the months of complete non-use.
So now that you've been proven wrong your response is to act like a fool and bury yourself further.You should find something more productive to do . . . Perhaps when the Cybertruck specs are posted you can be in a position to run your mouth. Right now - I'm not so sure.
