I also use it twice daily. My single-car garage is rather narrow and seemed to be custom built around a VW Beetle...
The unintended but very welcome side effect to the interior drop of the lip is that since the garage is so shallow, the 8" minimum distance isn't quite far enough in for the garage door to close to my satisfaction.
What do you have the summon distance set to? Maybe it is just something about the way you described it, but it is alarmingIt ends up going like 45 to 50 feet. How come it does that?
@kevinf311 Your garage sounds similar to mine: detached single car garage built ~86yrs ago. I think that pre-dates the VW bug!
Clearance through the door frame only 3" per side with mirrors extended (looks a heck of a lot less than that as I park the car. Yes I fold the mirrors in if I've misjudged the approach.)
To the OP:
I would use summon daily to park the car if it weren't for the minimum setting of 20cm (8") for front bumper clearance. I've tried it several times and it safely navigates the narrow width of the garage door. Seems reliable, no anxiety watching it do its thing. But my garage is both narrow and short - to safely close the garage door and leave enough clearance from the trunk, the car needs to be practically touching the front wall (closer than the photo above) which summon can't do by itself.
Unless they reduce the min setting of 8"/20cm by a couple inches (maybe a limitation of the ultrasonic sensor resolution?), right now I have to manually drive the car a couple inches closer after I park using summon, so that basically defeats the purpose.
When backing the car out of the garage using summon, often it will abort before it reaches the preset distance. I assume this might be caused by the car switching internet connection from wifi in the garage to LTE? Not sure but that's my guess. Note that here in Canada you can ONLY summon by continuous press of the button in the app, no fob summon supported here.
I have had it set for 30, 20 and 10 feet but it does the same thing. I was in control, i had the fob in my hand but I wanted to see how far it would go. I wouldnt have let it get out of control.What do you have the summon distance set to? Maybe it is just something about the way you described it, but it is alarming
that you didn't just use the fob or the app to stop it when it went farther than you wanted -- it suggests, perhaps wrongly, that
you weren't remaining in control throughout the procedure.
I figured -- just checking. So, definitely call Tesla service -- something is scary bad wrong here.I have had it set for 30, 20 and 10 feet but it does the same thing. I was in control, i had the fob in my hand but I wanted to see how far it would go. I wouldnt have let it get out of control.
If you summon your car into the garage, the next time you activate it you will "unsummon" your car -- it will stop where it was when you first summoned it. If you pull in by yourself, pulling out is a "summon" and not an "unsummon," so it will travel the full distance set in the configuration page.I usually pull mine in the garage my self but like to use summons to pull it out. But sometimes, it pulls out and keeps going. Down the driveway and heading out to the street. It ends up going like 45 to 50 feet. How come it does that?
Right, which according toit will travel the full distance set in the configuration page.
is nowhere near 45-50 feet.I have had it set for 30, 20 and 10 feet
Not disagreeing with that. But, did he measure 40-50 feet? Or is this just an estimate?Right, which according to
Exactly. it just keeps on going..... But still, good info to have on the summon / unsummon.Right, which according to
I walked it off, so kinda measured. Went at least 3 car lenghtsNot disagreeing with that. But, did he measure 40-50 feet? Or is this just an estimate?
I am also often doing blindly, commands the car to get out from inside the house, then go back to finish getting ready while the car gets out and closes the garage door.
I do check that nothing is on the driveway through the window, and locate the kids first
