Dammit another puncture!
Discussion in 'Model S' started by keith7465, Jun 10, 2020.
  1. keith7465
    keith7465 Member
    SoCal
    After getting a screw in the sidewall 7 days after delivery, my wife is right now on the side of the freeway with another flat (OK it took 10 months for this one).
    But the tire is totally flat. What's the use of a 'run flat' if it doesn't run whan flat???
  2. PWlakewood
    PWlakewood Active Member
    US
    Did you purchase run flats? Or are you on the stock tires?
  3. krsgio
    krsgio Member
    Colorado
    Don't think Tesla offered run flats from the factory to my knowledge so unless you replaced the tires after your last incident with run flats you're just using standard tires which obviously go flat when damaged.
  4. keith7465
    keith7465 Member
    SoCal
    Well that will explain it. I thought they would have been run flats since no spare offered. They are stock 21" wheels/tires.
    Anyone have any recommendations for aftermarket ones which fit the 21" rims? I wouldn't want to go and change all 4 though so I guess I'll be living with what we have.
  5. PWlakewood
    US
    You can purchase as many as you need from a local tire store, tesla, or online. Do you have Michelin or continental?
  6. AMPd
    AMPd Active Member
    Northern California
    I had to replace 4 tires in 1 year due to nail punctures! Crazy
  7. PWlakewood
    US
    Pro tip....quit driving on nails
    • Funny x 3
  8. AMPd
    AMPd Active Member
    Northern California
    ... no!
    I was actually starting to think someone was doing it to me on purpose.
  9. Naekuh
    Naekuh Member
    Los Angeles
    im giving my car acupuncture... Its supposed to work out all the bugs.
    As for me, its honestly not the nails but the potholes...
    FML... i went though 3 tires in 1 yr because of potholes side wall damage, but lucky i have not bent or cracked the rim.
    (goes finding a tree to knock on for good luck)
  10. PWlakewood
    US
    .....pro tip........potholes........
  11. houstonian
    houstonian ಠ_ಠ
    Houston. Duh.
    Oh man. This thread broke a damn in me.
    I work in RE and my duties largely revolve around me visiting our sites, often in or close to construction zones or near heavy industry installations.
    The net effect from this is I blow out a tire about every 4-6 months like clockwork. It’s insane. Also means one of the best investments I made was buying a 5th wheel from TSLA for a spare and a Quickjack!
    I’ve also mastered the road hazard claims process from TireRack and I guess it’s a plus I’ve not had to buy - our of pocket that is - new tires in a few years despite going through 5-7 (...I’ve lost count) replacements under TireRack’s RH warranty.
  12. Naekuh
    Naekuh Member
    Los Angeles
    pro tip dont live in Los Angeles?
    I dont think there is any other way to go by your tip...
  13. Silicon Desert
    Silicon Desert Active Member
    Sparks Nevada / GF 1
    hmmm, I am baffled. I was adding up the miles in Tesla and various other cars since the last time I got a flat tire and it amounts to over 250,000 miles across the USA, California and Nevada. Is this a recent new problem? Maybe my time is coming :eek:
  14. Mr. Jim
    Mr. Jim Member
    Santa Barbara
    3 tires in one year. I have a 2019 MX and last year I picked up a bolt on my right rear. The tire could not be fixed so I bought a new one to match the original Continental I had. Then 3 months ago I had another alert of low pressure on my left rear. Sidewall puncture so another new tire. Yesterday I went out and found my right rear completely flat so Tesla sent a tow truck and took it to their shop. Another sidewall, another tire. This is absurd. I've been driving for over 60 years and this has never happened before.
  15. 2101Guy
    2101Guy Active Member
  16. BrokerDon
    BrokerDon Active Member
    Newport Coast, CA
    We also live in SoCal and our 2015 P85D's 21" tires do seem to have more than their share of flats & potholes... probably because the the hundreds of thousands of cars & trucks on the roads here every day as well as all the road construction trying to burn up the CA "gas tax" money.
    We've always bought "Tire Certificates" from America's Tire which gets us a free tire if they fail before they wear out. Absolutely worth it with 21" Tesla tires especially our P85D's staggered Michelin Pilot $uper $port $ound dampened tire$... 4 replaced in 60,000 miles + 2 flat repairs, even on well maintained South Orange County roads (mostly Newport Beach).
    https://www.americastire.com/customer-service/certificates
  17. SO16
    SO16 Active Member
    MI
    19” are less prone to flats.....usually caused by potholes. Also are typically quieter. But of course they aren’t as “cool”.
  18. Flyguy
    Flyguy Member
  19. BrokerDon
    Newport Coast, CA
    19" tires & wheels are definitely less prone to flats since they're typically "skinnier" tires with taller treads. 19" are a lot less prone to pothole damage since their sidewalls are significantly taller.
    21" tires & wheels definitely look and handle sportier, especially on significantly lighter & stronger Arachnid wheels.
    I have both:
    • 21" Michelin Pilot Super Sport tireson on staggered Arachnida for well maintained SoCal / San Diego roads in dry season
    • 19" Michelin Primacty MX4 on Tesla Cyclone wheels for SiCal's short "rainy season" plus out of state road and snow trips
    Need the rght Tool for the right Job.
  20. r1200gs4ok
    r1200gs4ok Active Member
    Irvine California
    I had 2 within the first 45 days......had both repaired by Goodyear with patch from inside.....still holding air....run 45psi.....even were and have 8250 miles....still look new
