There’s a YouTuber who is putting a damp cloth on the handle of gen 2 chargers to keep the handle from getting too hot and forcing a reduction of charging rate.
Anyone know if this would work?
My M3 is new so I haven't had the opportunity to Supercharge yet. Is it just the handle that gets hot or is it the entire cable?There’s a YouTuber who is putting a damp cloth on the handle of gen 2 chargers to keep the handle from getting too hot and forcing a reduction of charging rate.
If it's the handle where the sensor resides, but if the entire cable gets hot during the supercharging process, then artificially keeping the handle cool with a damp cloth could cause the rest of the cable to become too hot.My M3 is new so I haven't had the opportunity to Supercharge yet. Is it just the handle that gets hot or is it the entire cable?
It just doesn't seems possible for the towel to cool it long enough to make a difference. Seems like it would just heat up the towel then perpetuating the hot condition.
YouTuber was Kyle Conner (former Tesla employee) that started Out of Spec Motoring. He's done various roadtrips and the cannon ball run.
His last road trip was with his girlfriend from NC to FL (work) then to SD. I think it was the episode where they went thru KS that they talked about and tested this (probably on several videos tho).
One of his YT channels: https://www.youtube.com/c/OutofSpecMotoring/videos
I think the road trip I was referring to was on another YT channel tho as I don't see it.
I doubt it makes any difference. The throttling should primarily be battery cooling. Throw a powerful fan pointing at the grill might help. If you have a faulty charge handle heating up it might help for a short bit. The towel (wet or not) could just as much act as an insulator.
There is a temperature sensor in the Supercharger handle. If it reaches a certain temperature, the SC will throttle down to keep the handle cool. These often overheat when very hot outside.
I'm sure it does, and it's to detect a faulty / weak connection. I've never had the handle get above luke warm.
Maybe it doesn't get hot enough here in the Northeast.
Remember that the second 1/2 needs to be done on a new pedestal ... vs cooling down the original. At least the new pedestal is what Kyle did IIRC.No wet towel for first 1/2 of the charge,
and then a cold wet towel for the second 1/2.
A 100 year record was broken in Death Valley yesterday. 130F.
I'll be supercharging nearby this week, and will do a little experiment. No wet towel for first 1/2 of the charge, and then a cold wet towel for the second 1/2. Evaporative cooling really does work, and I'll post the results to prove it.
Well it is make to charge in the rain or wet snow, so your safety risk comment doesn't make logical sense.I haven’t tried the towel trick yet, it seems like too much of a safety risk than it’s worth.
