Dangerous: Autopilot is nagging every 15 seconds. Why?
Discussion in 'Model X' started by Brandon332, Aug 25, 2016.
  1. Brandon332
    Brandon332 Member
    Hi all,
    I love our X, but over the past several days something weird has been happening when in Autopilot. The "Hold steering wheel" alert is coming up exactly every 15 seconds without stop, regardless of any other factors. I use it on the way to work and home so it's the same route I've been using for months, clear skies, average speed, no obstructions to the camera, different lanes used etc, so it's nothing unusual external to the car. About 75% of the time it comes on every 15 seconds, the other 25% is normal.
    It's dangerous because I have to look down at the screen rather than on the road, I almost crashed once! So I put my hands on the wheel all the time, but you all know that we need to tug the wheel to silence the alert, so it still appears every 15 seconds. So I haven't been using autopilot anymore. Does anyone know why this happens and how to prevent it? Thanks so much! :)
  2. X Fan
    X Fan Supporting Member
    Naples, FL & OIB, NC
    Used AP for almost 9K miles but haven’t seen that...it would be helpful to know your OS version and what type of road you are using it on.
    btw: have you rebooted the system with similar effect?
  3. BigMskiman
    BigMskiman Member
    Pleasanton, CA
    Not having that behavior on my X. It would distract me as well.
  4. RDoc
    RDoc S85D
    Boston North Shore
    "Hold" means actually grip the wheel, not just put your hand on it. There's no need to tug at the wheel, just grip it comfortably and let the wheel's motion move your hand and arm. I grip the wheel at the bottom touching the bottom spoke and never get a nag.
    If you are doing that and still getting nags, talk to service.
  5. kort677
    kort677 Banned
    florida.
    why do you need to look down? just keep a finger on the steering wheel, that said this is not normal and should get checked by a SvC
  6. cgiGuy
    cgiGuy Active Member
    Sacramento, CA
    Wow. I'm somehow not surprised by how many people are crashing their cars on AP with statements like this.
    At least you weren't petting your dog and cleaning the interior of the car around a curve while on AP.
    • Funny x 3
  7. Brandon332
    Brandon332 Member
    OS version 7.1, and the roads were main interstates. I've used the interstates every week since I got the car in July with no issues. I'll clarify, when I hold the wheel, 50% of he time the car doesn't recognize and it still gives the warning, 25% of the time it recognizes and lets me go for another 15 seconds, and 25% of the time I accidentally disengage autopilot. There's a very fine line between getting the car to notice you're holding it and disengaging it.
  8. 30seconds
    30seconds Active Member
    SF
    sounds like some sort of sensor issue
  9. davidc18
    davidc18 Active Member
    Ft. Lauderdale
    There are no sensors in the wheel. It senses torque, not pressure. You have to apply slight torque to remove the nag.
    set up a service appt. that behavior is not normal.
  10. Electroman
    Electroman Active Member
    TX
    You can hold the wheel as tightly as you want till your fingers turn blue. It will do nothing.
    You need to gently torque (turn) the wheel ever so slightly, just enough for the car to know you are alive and watching. If you turn too much AP will assume you want to take control and disable and give the control to you. It's easy, you will quickly learn how much to turn.
    • Funny x 2
  11. vandacca
    vandacca ReActive Member
    Hamilton
    This is totally subjective, but it appears to me that AP will nag more when conditions are not ideal. I find that when I'm driving on a large, straight road with new asphalt and lines, I rarely get nagged. In a high-traffic area with faded lines, I appear to get nagged more often. Maybe your route is deemed not ideal?
    Note: this is not a scientific observation
  12. RDoc
    RDoc S85D
    Boston North Shore
    Who said anything about sensors in the wheel?
    The torque the system senses from the inertia of your hand and arm plus the natural resistance of you arm to motion is more than enough to silence nags. There's no need to tug on the wheel.
    What won't work is lightly laying your hand on the wheel and letting it slip under your fingers. That will generate nags.
  13. X Fan
    agreed....btw: OP, Q was which specific rev. level of 7.1? I have 2.32.100. In any event, SC call make sense.
  14. Blastphemy
    Blastphemy Member
    Los Angeles, CA
    Same here.
  15. davidc18
    Ft. Lauderdale
    so we are saying the same thing differently
  16. systemcrashed
    systemcrashed Please Reboot
    Give tech support a call and as them to push the last update to your car again. Good practice to reboot after firmware update. Check your windshield and make sure the glass is clean in front of the camera.
  17. Trnsl8r
    Trnsl8r S85 2012-2018, X90 since 2016, 3 since 2018
    San Jose, CA
    My car is too old for AP so I don't have the experience here, but wouldn't it make more sense to have a different function to let the car know you're awake than yanking the wheel? Could you have an alert show up on the screen or something that you have to tap to show the same?
  18. EV Family
    EV Family Like Tesla
    Georgia
    I've had the same observation.
  19. systemcrashed
    Same here. Traffic volume change, and road conditions/contrast also triggers it for me.
  20. Electroman
    TX
    #20 Electroman, Aug 26, 2016
    True. I have had days when it will nag just once or twice in my 40 mile commute. Typically that would be when I am driving very early in the mornings or later at nights or weekends when there is less traffic, or on the other extreme when the traffic is just stop and go and crawling.
    It nags a bit more when there is dense traffic zipping at high speeds and folks are cutting you off in and out, traffic slowing abruptly. When the system is a bit more stressed.
    It all makes perfect sense.
