Dash Cam installation in DFW
Hi All
I had someone back their car into my bumper a month ago but long story short had to file a claim and pay my $250 deductible for uninsured motorist damage.
I want to know if anyone had their dash cams installed and how much it costs to install.
I want both the front and back dash cams to be installed.
Thanks
I installed the Blackvue dashcam for both the front and rear windows. Since I did the install with a friend, there was almost no cost. I did buy him a dinner & some beers. :)
I like the fact that it records all the time & I don't have to pay attention to it. I've pulled off video captured from it and posted a shortened clip onto Facebook.
Dislikes:
--The rear cam is not nearly the same resolution as the front cam, and is (in my mind) almost worthless.
--The GPS rarely works--Tesla Model S glass blocks the signal. I wish it had a port for an external antenna.
--The WIFI signal is blocked by the glass, so I can only use that feature inside my car.
--The time stamp is often wrong--probably blocked by the glass from updating the clock.
--Removing the micro SD card is a pain--it should be more accessible. For that matter, if it had a USB port, you wouldn't need to remove the card.
I did mine myself, but it was trivial since I have an accessible power point behind the speaker grill above the rear view mirror. An owner at the Dallas service center spoke highly of Car Toys, though I have no personal experience with them. I'll probably shop around later this year when I add a second camera (facing rearward) because I don't want to do that myself. I'll probably just buy another Lukas, the same as my front camera, so that I don't compromise resolution from the rear.
Dislikes:
So I called Car Toys in Dallas and they seem to charge $1500 or so to install cams both front and back but this is a rough quote only. Given the fact it might be $1500 or so....is it worth it?
- - - Updated - - -
Thanks Rockster ...I did call Car Toys and I will look for Lukas...Do you happen to have any issues with it?
I had the
[SIZE=+1]Blackvue DR650GW [/SIZE]
installed into my P85D at earmark audio in lewisville. I bought the camera online and took it to them. They charged $267.59 for the install. Talk to Joe Parker 214-222-0974. PM me if you want more details.
That is very subjective, and I can't mind-read. You can find cheaper installs, but sometimes you get what you pay for.
I will say that I think it is worth having a dash-cam. Is BlackVue the best one to get? I'm not sure--it seemed to be last summer, but I stopped looking at the ratings once I bought mine. I have noticed that several people have complained that customer support for the BlackVue is almost non-existent. If you have a defective system, you might be out of luck.
