  • The final cut of TMC Podcast #27 is available now with topics time-stamped. We discussed: Consolidation in LiDAR manufacturers; Volvo EX90 shipping with LiDAR; FSD Beta Full Release in N.A.; FSD detecting autopilot cheats, Gwen Shotwell directly overseeing SpaceX Starship; and more. You can watch it now on YouTube. We should have it published to podcast networks shortly.
Dash Cam Not Working Check USB
Is it the dash camera feature not working or the backup camera? If the dash cam then possibly worth a couple weeks to hold off until the next software update. I'd hate for you to spend that if you don't actually have a hardware failure. If there is a wiring harness that is damaged and the backup camera alone isn't working then it would need to be repaired or replaced. I have seen rodents get into areas and chew up wires as is a possibility with any car.
It’s actually both cameras that are not working. Backup camera and dash camera
Ok thanks. From what I understand the dash cam issue where the USB drive says disconnected and you unplug and plug it back in to get it to work, should be fixed soon by software update. Backup camera not working likely is a hardware issue such as a chewed wire or bad component. Hard to say without seeing it. Hope that helps a little.
Thanks again for the information and your response.
