AdamNS
Thank you! I was looking into DPDT switches and was confused how Id wire it up. Is the one you linked 12V compatible? The only DPDT switch I found that said it was for DC 12V was a momentary one:
https://www.amazon.com/Momentary-Automobile-Power-Window-Switch/dp/B009ERVR6G
Yeah, Almost any DPDT switch will work. This is very low voltage and amperage. (though as you noted, don't use a momentary switch)
The main differences in switches you will see is "on - on" vs "on - off - on". The difference there is that the former has only 2 positions and you are either connected to one thing or the other. The latter has 3 positions on the switch: Up is connected to one thing, Down is connected to the other, or in the middle is connected to neither. For this application, it's really just a preference if you want an "off" position or not.
All of these should work:
http://a.co/581sYbG
http://a.co/6kL5rnd
http://a.co/bbrRW8Z
http://a.co/7C3PmHQ
http://a.co/ipv8npi
http://a.co/c1GOy4z
... you get the idea
