I pop it into a pc and clear most of it every couple of months.This warning triangle is displayed on my screen with the warning “Dashcam USB drive is getting full”.
Why is this displaying? I thought it just overwrote the old stuff?
in case you want to save the stuff on thereIf it overwrites what’s the point of telling me the drive is nearly full?
takes all of 5 secondsAll you need to do is format the drive from the touchscreen, A format clears it all and makes the TeslaCam directory, couldn't be more simple
really the only complaint we should be having is that it should be easierto transfer the files via your app or some other way to your phone. that way you could keep the videos you want and make it easier to share them and then easy enough to reformat and wipe the drive once theyre savedI kind of agree with Pagemakers though, format erases everything. I often record interesting things with the dashcam that I might want to keep. Sentry mode is useless after a week or so as I'd have noticed by then if anything had been damaged etc. So the practice of overwriting sentry clips and leaving dash cam is fine, so why warn about it more than once. I only manually delete my sentry clips to get rid of the warning.
I totally get that. That’s not my point.All you need to do is format the drive from the touchscreen, A format clears it all and makes the TeslaCam directory, couldn't be more simple
It's not supposed to overwrite Sentry and Saved clips. If you want to get rid of it without taking it out, format the drive in the car (like the warning message says)IF it is supposed to overwrite the old stuff
More software not thought out properly.
Is a permanent warning triangle really proportional or necessary? Sentry clips beyond a week are no use if you’ve not noticed damage in that time. FfsIt's not supposed to overwrite Sentry and Saved clips. If you want to get rid of it without taking it out, format the drive in the car (like the warning message says)
Actually it's thought out properly in this case. It should not automatically overwrite sentry clips - the whole point is to save them in-case you discover damage later. It's a pretty simple procedure to format the drive in the car or delete sentry footage with your computer.
If you don't like the function, turn sentry off completely and the drive will never get full ---- until it fails from years of overwriting as all memory does.
You could also purchase a much larger drive to reduce the frequency you need to spend 10 seconds to reformat it.
