DashCam Wiring - Refreshed Model S
Discussion in 'Model S' started by radelman601, Aug 18, 2016.
Tags:
  1. radelman601
    radelman601 Member
    San Antonio, TX
    Hello.
    I apologize if this is already discussed on another thread. I have been watching several threads related to installing a DashCam but there seems to be a lot of back and forth relative to the where to tap into the constant 12v connection. I am going to install a new Blackvue 650S 2-channel unit and need to know where I can tap into the 12v connection in a REFRESHED Model S so I can fully use the features of the camera even while parked.
    Would appreciate feedback.
    Thanks!
  2. Tech_Guy
    Tech_Guy ALWAYS IN LUDICROUS MODE! P90D>P100D Upgrade
    Los Angeles
    I'm the microphone grill there is an extra connector you can use as discussed in all of the dash cam threads with step by step pictures!
    • Like x 4
  3. radelman601
    radelman601 Member
    San Antonio, TX
    Thanks. When you review the threads it is sometimes hard to keep track of what is in the microphone grill area and what it isn't based on the flavors of vehicles.
  4. Cmer
    Cmer Member
    Toronto
    I'll be in the same situation in a couple of months when I get my MS.
    Is there a specific plug/connector I need to connect a dash cam to the power connector in the mic grill? I'd like to order all the parts now. thanks!
  5. Cmer
    Cmer Member
    Toronto
    My understanding is that early MS had the connector, then between 2014-2015 or something like that, they stopped including the connector, and now the connector is back in 2016. (I'm sure I got my dates wrong). So anybody buying a MS from now on should have the connector.
  6. Tech_Guy
    Los Angeles
    The wires are available on the USA refreshed car, if you have the european car the wires are used for the alarm I believe and not available.
  7. radelman601
    radelman601 Member
    San Antonio, TX
    Thank Tech_Guy!!!
  8. whitex
    whitex Active Member
    Seattle area, WA
    You can always check. The microphone grille comes down in 2s or less (at least pre-refresh it does), look inside. Check this forum for pictures of what it looks like and pinout - only 3 pins, I just used a volt meter for my wiring but I know I've seen labeled pictures in few posts here.
  9. sorka
    sorka Well-Known Member
    Merced, CA
    It takes about 10 minutes to route it through the headliner, down the a-pillar trim, and to the OBD-II connector.
  10. wilheldp
    wilheldp Member
    Louisville, KY
    • Informative x 2
  11. ND100
    ND100 Member
    NSW
    If you go down this path, how are people dealing with the fact that parking mode on many cameras requires use of both constant power and ACC-only power? Or are people leaving their cameras recording all the time/manually enabling/disabling?
    Also, does anyone know if the power connector in the microphone area in refreshed cars is available in AU spec cars? (Haven't received the car yet)
  12. fallen888
    fallen888 Participant
    Newtown, PA
    I'll be attempting this next month as well. I just googled and found this: Dash Cam | TeslaTap
    Hope it's helpful.
  13. ND100
    ND100 Member
    NSW
    I wonder how the "route the cable to the frunk" actually works out (hard to tell from those photos). I've also had luck in the past routing cables to the rear of the car by feeding from the A pillar to the rear of a car without removing the headline itself. I'm curious whether that's also going to be true with the Model S.
  14. whitex
    Seattle area, WA
    Blackvue doesn't require switched - it automatically switches from parking to normal mode and back, plus the event mode triggered by G sensor.
  15. Frankman60
    Frankman60 Member
    San Diego, CA
    Thanks, I ordered the 12v connector with the Blackvue dashcam. I want to mount the cam behind the rear view mirror on my refreshed MS. But I see some horizontal slots on the black plastic housing that the dashcam would be mounted directly in front of. Does anyone know what these slots are for and if the dashcam in front of them will cause a problem?
  16. wilheldp
    wilheldp Member
    Louisville, KY
    They are fins on the AutoPilot sensor heat sink. I don't know how hot they get during use, but I decided it would be best to route the wiring to the right of them. The power and rear camera wires go into the headliner just to the right of the AP camera housing on mine, and it doesn't look bad at all. I would have preferred to run the wiring down the rearview mirror housing, but I couldn't see a clear path to route them into the rearview.
  17. Chopr147
    Chopr147 Active Member
    Wantagh, NY
    I should have the Blackvue and assorted connectors delivered today UPS. If I get them early I will install today and re- post my progress.
    Looks to be an easy install but I have said that before and been oh so wrong :(
  18. ernie
    ernie Member
    With the mic grill install for power, are you cutting off the bulky 12V plug of the Blackview and wiring it direct or keeping it intact and stuffing all the wire behind the grill. I remember reading the blackvue had a voltage reduction through the plug and that's why it voids the warranty if it is cut off. Thx.
  19. Chopr147
    Wantagh, NY
  20. dss33
    dss33 Member
    Seattle
    Nice! I'm looking at this install myself. Any chance you can post a list/links for everything you purchased along with the install steps? I know they're sort of out there already, but it would be great to have a fresh one that I know is current. Good luck with the install!
