DashCam Wiring - Refreshed Model S
"The 12V power connector has voltage reduction circuitry, so can’t just clip it off and wire the dashcam directly to 12V."
Dash Cam | TeslaTap
I clipped mine off and have had no problems yet in 3 months... reading the comments the first one says
26-Jul-2016 at 8:16 am
This was true on the 500 series (voltage reduction was done inside the plug). I don’t know for 100% on the newer 600/650 models, but I think they may have removed the voltage regulator from within the plug. I’d check with the manufacturer first just to be sure."
On a 2018 model S can you connect 2 power wires to the 12v wire inside the microphone panel? I want to install the Blackvue 750s 2ch-IR and a 900s 1ch. I will use the 900 for the front and the 750 for the rear and interior. I believe I will have 2 power wires that I need to connect and was hoping to just use one power source. FYI I want continuous recording.
