Great post and timing, i've recently been thinking about buying one myself lol. From what i've seen, Aim Solo 2 is also quite popular: Aim Solo 2 | Aim Technologies
You can also get a cool mount for the dash from ProClip USA, it has a relatively large flat surface that would enable drilling and mounting a few different things (i.e potentially an Aim Solo 2): 2019 Tesla Model 3 Dashboard Mounts | ProClip USA
My understanding is there are active efforts to decode what is available. Once decoded, these are sent to the developer who handles integration. But it looks like there are open, CAN bus options in 'Scan My Tesla' to help with the decode effort. I'm not part of that effort since the things I'm interested in are already there or the other metrics can be independently collected and integrated in the spreadsheet.
I'd recommend looking over the Owner's group threads and possibly contacting the members doing the heavy lifting.
I use Harry's Laptimer and TrackAddict, both at iPhone based, can record video from the phone and sync start/stop with an external cam like GoPro. I've MPP MoTec system as well, but I haven't had the time to get it correctly set up and learn how to use it.
The Tesla has to be in gear, "D" or "R", to see all of the "scan my tesla" data points specific to your version. So I recorded the "All" table to make this list for our SR+ Model 3:
Time (ms)
Battery voltage
Battery current
Battery power
F power
R power
F torque
R torque
F torque 186
F RPM
R torque 108
R RPM
F Inverter PCB temp
F Inverter temp
F Stator temp
F heatsink temp
R Inverter PCB temp
R Inverter temp
R Stator temp
R heatsink temp
Max discharge power
Max regen power
Max pack voltage
Min pack voltage
Max discharge current
Max charge current
Max charge power
FL brake est
FR brake est
RL brake est
RR brake est
Steering Angle
Steering Speed
Accelerator Pedal
Brake Pedal
Consumption
DC Charge total
AC Charge total
DC Charge
AC Charge
Regen total
Drive total
Regenerated
Energy
Regen %
Odometer
Distance
Avg consumption
Nominal full pack
Nominal remaining
Expected remaining
Ideal remaining
To charge complete
Energy buffer
SOC
SOC UI
SOC Min
SOC Max
SOC Avg
Cell temp max
Cell temp mid
Cell temp min
Cell volt max
Cell volt mid
Cell volt min
Cell imbalance
Battery min temp
Battery inlet
Powertrain inlet
Outside temp
Outside temp filtered
Series/Parallel
Target PT ActiveCool
Target PT Passive
Target bat ActiveCool
Target bat Passive
Target bat ActiveHeat
Battery flow
Powertrain flow
Charge total
Discharge total
Discharge cycles
Charge cycles
Discharge
Charge
Stationary
Blower speed target
Evap enabled
Evap temp
Evap target
Duct left
Duct right
Heater left
Heater right
Cabin humidity
Cabin temp probe
Cabin temp mid
Cabin temp deep
12v battery volt
12v battery current
12v battery Amp hours
12v battery temp
Speed
0-50
0-60
0-100
0-130
0-160
0-200
60-100
80-120
Packets per second
A MacOS user, "AirDroid" is an excellent utility, $25/yr, that creates a Web server on the Android. You can quickly navigate to the folder holding your files and download them onto the Macintosh. It shows an IP address and port that becomes the URL to access the web server, for example http://192.168.0.12:8888. Once opened, it becomes trivial to get the files moved to the MacOS system.
