Dc combo for USA port
Discussion in 'Supercharging & Charging Infrastructure' started by Wkwjsrjal22, Aug 7, 2020.
  1. MP3Mike
    MP3Mike Well-Known Member
    Oregon
    The Tesla EU CCS adapter is ~142kW, so I would think that the Tesla one would be similar.
  2. dgpcolorado
    dgpcolorado high altitude member
    The Western Slope, Colorado
    The CCS2 adapter in Europe seems to need changes to the car. From the CCS2 adapter manual:
    Given the difference in signalling protocols between Tesla/Chademo and CCS, this doesn't seem surprising to me.
  3. khorton
    khorton Member
    Moses Lake, WA
    They don't make the only one that is currently on the market, which was the original subject of this thread. I was tempted to buy that one, until the rumors of this Tesla one appeared.
  4. pb2000
    pb2000 Member
    Calgary
    Not if it makes it ridiculously expensive. I'd be far more interested in a 35kW adapter for $200, than a 200kW $750 adapter.
  5. lowtoast
    lowtoast Member
    Detroit, MI
    150kw would be amazing, that's pretty much the limit of the SR+ anyway. It'd be as good as supercharging.
    Interesting, I would pay more for higher speeds, but I have a salvage and can't use supercharging. I rely on 3rd party fast charging for travel.
  6. pb2000
    pb2000 Member
    Calgary
    I just want something to fill in gaps in the supercharger network and give me other charging options.
  7. lowtoast
    lowtoast Member
    Detroit, MI
    I bet that's what most people are looking for, for now.
    I think longer term there is potential to supplement the supercharger network in a meaningful way.
  8. theothertom
    theothertom Member
    South Carolina
    Sorry. There are a couple of threads on this subject. I wasn't paying attention to the original subject.
  9. theothertom
    theothertom Member
    South Carolina
    Yes, but the Korean adapter is 200A (or about 80kW) so the Tesla adapter might be similar. Of course I'm hoping for at least 150kW.
  10. SigNC
    SigNC Active Member
    NC
    If you want a 35kW adapter get the chademo one :p
  11. pb2000
    pb2000 Member
    Calgary
    I held off on buying one initially because it was pretty apparent that CCS was the way forward. If the CCS adapter is significantly more expensive, then I may end up going that way, despite the dead standard.
  12. SigNC
    SigNC Active Member
    NC
    So i was thinking about this. companies like EVgo and electrify america have to want this to be a thing right? I get that other CCS cars likel don't want tesla filling up their chargers but the companies have to want the business so they can get over the chicken and the egg hump right?
  13. e of pi
    e of pi Member
    Greenville, SC
    Yeah, I think for EA and EVGo or state or local agencies looking to install chargers, Tesla switching to the common standard (even just to the extent of putting out an adaptor) is great. I'd love to have to compete against Teslas for charging spots, because it increases the odds of the people running them building more. Agencies or companies wouldn't have to pick which type of charger to install, just decide to install a charger, period.
    Two separate networks becoming one interoperable grid twice the size is better for everyone in Level 2, too. At my local supermarket, we used to have a pair of J1772 chargers in the lot. A year or two back, they pulled one out and used the conduit to install a Tesla Level 2 charger. Before, if you pulled in and there was another car there, you could count on still getting an open plug, so getting to see another car using it felt good. Now, if there's another car there, it's likely that station is already full and I basically never count on getting a charge there. Telsa switching to CCS (and thus also to being able to support J1772 for Level 2 charging) would be great for the standards problem across the board, not just DCFC but also for slow/destination charging.
    A CCS adapter wouldn't just serve to replace the DCFC Chademo adaptor, it'd probably also be able to replace the existing Level 2 J1772 adapter. Two parts and things to lose become one part. Having the port on the car, the way it is in Europe, would be even better than that, but it's still an improvement for EV as a whole when a Tesla CCS adapter finally becomes available in the US.
  14. MP3Mike
    Oregon
    Probably not. The CCS adapter would route the extra two DC pins on the bottom to the charge port, and the upper AC pins wouldn't be wired to anywhere. You would still need the J1772 adapter for AC charging.
  15. e of pi
    e of pi Member
    Greenville, SC
    You definitely could build a CCS adapter with live AC pins which can also do J1772, but you're right they could also choose not to bother. However, making those pins live and the signaling to have it work for both is a little more money per unit. I just think it'd be silly to skimp on maybe $10-15 in additional cost that let a single adapter do a job which otherwise two adapters are needed for.
  16. MP3Mike
    Oregon
    I think it would be more involved than that. You would have to have multiple contactors in the adapter to route the charge port pins to either the AC or DC pins in the adapter. That would be either two or four rather large contactors that would need power from somewhere to operate. So the adapter would be much bigger, more complicated, and more costly. I would say there is a 0.001% chance that Tesla would do this. (And given the picture of the adapter that has been shared I would say that there is a 0% chance that that adapter can be used for AC charging.)
  17. e of pi
    e of pi Member
    Greenville, SC
    Huh, so Tesla uses the same pins for AC and DC on the car side, with some switching on the car side the adapter would have to match? I hadn't realized that. If so, it does could like it'd be more complex than the adapter they've shown (though probably something you could do with something more like the Setec version).
  18. Randy Spencer
    Randy Spencer Active Member
    Alameda, CA
    Huh? Was that run thru Google Translate a few times? I cannot make heads or tails
  19. e of pi
    e of pi Member
    Greenville, SC
    Should have been "does seem like it would be more complex than"
  20. Forty_Too
    Forty_Too Member
    Chicago, IL
    Well. I decided to be a guinea pig. I just got a shipping notification - should be arriving Monday from Hong Kong. We’ll see how this goes!
    • Like x 4
