Hi all,
Finally yesterday got around to fix my DC/DC converter/fuse issue, for sure the fuse was the issue, replaced both big once.
Quite straightforward process as all have stated, even got inside the DC/DC converter quite easy and fast. I think because we were two, used small screwdriver to open extra space for the razorblade to move forward much easier.
Anyway, once we put back everything together the A/C compressor started to work right away and the cold returned.
Last night left the car to charge overnight at work at the 32A charger and today when drove 15 minutes from work with the A/C on it stop working again. The compressor does not kick-in it just clicks, but it does not start. Usually, I have a quite noticeable noise when it is all fine and working, which was music for my ears yesterday. Unfortunately, today again is not a good day.
For now I am think of opening again the DC/DC converter later next week to check if the fuse is good or now the A/C converter is the issue, but I am running with ideas and options. Could it be the A/C coolant, not sufficient since last top-up?
What do you guys think?
Thanks
