Ok, here are the symptoms.
Drove car yesterday. It was fully charged (90%) when I left. Discharged maybe 20 miles and returned home, plugged car into Tesla Wall Connecter, everything clicked/lit up as normal.
this am, went to car, nothing. Can’t use keycard, can’t use phone. Doors locked (which they actually shouldn’t be because I have auto-lock off at home). Strangely enough, the mirrors are still extended. If auto lock had kicked in, mirrors should have retracted.
looked at app, car was last seen 16 hours ago, right when I parked it. Phone. It showing a Bluetooth connection to car.
Walked around car, front passenger door opened. It now won’t close because the latch mechanism is electric. How did it even open?
I got in, climbed into drivers seat, stepped on brake, tried the two button and two button plus brake resets and nothing. Car is completely dead.
did procedure to get to 12v battery. Used NOCO Boost portal jump starter to open frunk, got to 12v and tested with multimeter. 11.4 volts. That’s full for a 2 year old battery. Tried NOCO Boost anyway and it came back saying battery was full.
I can not remove the charging cable. Wall connecter is on and its light is blue. But the port is locked. So at this point I can’t even tow it.
Out of ideas. Help.
Out of ideas. Help.
