Dead Roadster 2.5 in Norway
Discussion in 'Roadster: Technical' started by Cirion, Jun 6, 2020.
  1. Cirion
    Cirion Member
    Norway
    Short story, PEM died, Tesla replaced it, and the battery died while waiting.
    Picked up my car, since the options I got from Tesla was ship the battery to Tesla US for repair, or order a 3.0 battery.
    If anyone has any info on how to order the BMB PCBs from Nick and the connectors, chargers and so on to make them work, I'm able to assemble them and give it a try.
    Now, I replaced the 12v battery, and connected a battery tender to supply it with 12v. I get headlights and hazard lights, but the rest of the car is dead. I have measured 13.78V at the 30A fuse under the hood, and the same at the headlight fuses. But the rest of the car shows 0.41V.
    The service disconnect is out, does it need to be in to get the rest of the car to work? I mean, doors, display, stereo, windows....
  2. Cirion
    Cirion Member
    Norway
  3. dhrivnak
    dhrivnak Active Member
    NE Tennessee
    Sorry to hear of your trouble and good luck.
  4. drewski
    drewski Supporting Member
    SF Bay Area
    if it died in Tesla's hands, shouldn't they foot the bill for getting the car running again?
  5. Bunnak
    Bunnak Member
    Orange County, CA, USA
    It's stories like this that I'd rather not have Tesla SC touch anything PEM or battery related when it comes to the roadster. But I do understand that in Europe you don't have many choices.
  6. PV-EV
    PV-EV Member
    Alaska
    The VDS, VMS, instrument panel and a few other things are powered by the standby power which comes from the ESS connector J4 pin 1 (+12v) and pin 2 (ground)
  7. Cirion
    Cirion Member
    Norway
    Ordered the BMB probes from China PCB Prototype & Fabrication Manufacturer - PCB Prototype the Easy Way, after a chat, they told me to just zip the folder and select 100x100 and pick the colors I wanted for the board. They would adjust the rest from the drawings if I attached the zip file.
    All the connectors are available from https://www.mouser.com/.
    Next part of the pussle, what charger to use? How to limit the voltage and amps to 100mA. What voltage should each cell reach before the onboard charger will allow charging?
  8. Cirion
    Cirion Member
    Norway
    Boards arrived!
  9. Cirion
    Cirion Member
    Norway
    Feels like christmas. DC-DC stepdowns arrived :)
  10. Cirion
    Cirion Member
    Norway
    First board pulled:
  11. Cirion
    Cirion Member
    Norway
    Tested with 2 boards, and both sheets show 3,98V per cell and 35,9V on the last.
    Is that not high?
  12. Cirion
    Cirion Member
    Norway
    Cell1 Cell2 Cell3 Cell4 Cell5 Cell6 Cell7 Cell8 Cell9
    Sheet1 3,9 7,9 11,9 15,9 19,9 23,9 27,9 31,9 35,9
    Sheet2 3,9 7,9 11,9 15,9 19,9 23,9 27,9 31,9 35,9
    Sheet3 3,9 7,9 11,9 15,9 19,9 23,9 27,9 31,9 35,9
    Sheet4 3,9 7,9 11,9 15,9 19,9 23,9 27,9 31,9 35,9
    Sheet5 3,9 7,9 11,9 15,9 19,9 23,9 27,9 31,9 35,9
  13. Cirion
    Cirion Member
    Norway
  14. ML Auto
    ML Auto Member
    SW Florida
    If those readings are correct, your battery is charged and fine. You need to put the service disconnect back in and see what happens. Why did you think the battery died in the first place?
  15. Cirion
    Cirion Member
    Norway
    Tesla told me it was dead after PEM replacement.
  16. Cirion
    Cirion Member
    Norway
    After reseating all the BMB boards and plugging in the service disconnect, the car woke up.
  17. Cirion
    Cirion Member
    Norway
  18. Cirion
    Cirion Member
    Norway
  19. Cirion
    Cirion Member
    Norway
  20. Cirion
    Cirion Member
    Norway
