Debadging
jpizz123
32
10
earth
Hey guys, I'm trying to debadge the "Model X 75 D" but I noticed that the "Model X D" badge seems to be stuck on with some serious glue, only the "75" part seems to be stuck with normal double sided tape. Any recommendations on defeating the glue without messing up the paint? Thanks!
djillusion
216
87
Chicago
Get a hair dryer and apply heat uniformly to the badge. Spread the heat around and not just one specific letter / character. Use dental floss behind the characters / letter and work the floss through the glue. That should do it.
Reactions: wreighven
jpizz123
32
10
earth
Thanks, did you debadge yours? If so what did you use to remove the glue from the car? I have goo gone and goof off but don't know which one would be best. Also was your emblem glued on or did it have the double sided tape?
djillusion
216
87
Chicago
I didn’t debadge my X but have done it with other cars. Most badges are glued on via some adhesive.
I used goo gone and then wash the car, detail/wax it etc to ensure a smooth final result.
jpizz123
32
10
earth
Yeah I debadged my other cars too and luckily they were just stuck on with double sided tape. This is the first time I've seen glue so hopefully it'll be alright. BTW your car looks super clean!
SUP THO
73
59
San Francisco
OP can you please share pics when complete. Depending on how old your car is I’m wondering if the shade of paint behind the badges are discolored. Did it leave any glue residues?
highly considering removing “DUAL MOTOR” from mine as well.
MitchV
9
-22
Unrelated to the Model X, but in one of Sandy Monroe's Model Y videos, Tesla had punched a hole in the surface to mount the Tesla badge... I wish they hadn't done that. /sigh
Perhaps we need a petition so that Tesla doesn't do the same thing with the Cybertruck.
Hwood
145
51
Texas
Cy
cybertruck will have zero logo and badges. That’s the new branding strategy
Reactions: MitchV
Skydiver42
11
10
Louisiana
Not OP but here is my 75D debadged. Mine is a late 2017.
Reactions: SUP THO
Yinn
2,080
1,857
Behind you
Your hair dryer has to get hot enough too. If it doesn't do the trick, go to Harbor Freight and pick up a heat gun for $10. Apply heat and the adhesive will loosen up. Then take fishing line or floss and slide it behind the letters to get it started and then you can peel.
Once it's peeled off, reapply heat and you'll be able to rub the glue into thicker pieces to pull off. There may be some residual, you can futz with it to get it perfect, try rubbing alcohol, or I typically grab some 3M adhesive remover. Put some of that on a cloth and wipe, no extensive rubbing needed.
