I know from looking at the chart as I described it to you above (Power Vs time) that the Tesla algorithm handily beats 150 kW constant in any situation starting from 10 - 20% SoC going up to as much as 80% SoC.
This and your other post with power/time chart. The thing is, there is no power/time chart here. So if you are making your observation on the charts present here they are just guesses. From what I've found so far regarding V3 supercharging Model 3, you can get 80% charge in 40 minutes. From Audi's chart you can see that the tapering starts around 70% and it is very gradual, you can almost keep the same charging speed up to 80%. If you can average 140kw up to 80% that would be faster than the Tesla method.
The title of the thread is "Debunking Audi's 'sustained power beats top power'. And the OP then goes on (in the thread he authored) to compare EPA miles in his chart. That makes it undeniably clear what the OP's intent is, and thus what the thread is about.
No, it just means that the OP is trying to prove his point using the wrong arguments. His claim that because Tesla gains more mileage when charging(which I guess is true) means Audi's method of charging is inferior is wrong.
Having said that, It is true it's more complicated and depends on whether you are charging up to 80% or less. This also depends on a lot of things. I guess Tesla has optimized for faster charging times up to 50% which may seem more appropriate in some cases. However you also have to understand not all people live in US. Here in Europe there are plenty of countries with highway speed limits up to 140km/h(87mi/h) and this drains the battery really fast. Being able to charge fast for longer is important as well.
