Decreased range with performance package?
Discussion in 'Model S' started by Dan5, Jan 2, 2012.
Tags:
  1. Dan5
    Dan5 Member
    Delran, NJ
    Do you think the range will decrease slightly due to the high performance inverter?
    My way of thinking is that the inverter should have more wattage so it should be slightly less efficient driving from point A to point B, but provides enough for a surge (increased 0-60).
    If it weighs a few lbs more, that will not decrease the range significantly
  2. ckessel
    ckessel Active Member
    Tesla says it shouldn't affect range. From their Features page:
  3. NigelM
    NigelM Recovering Member
    Northern Virginia
    The temptation towards rapid right foot depression will probably reduce range....
  4. AnOutsider
    AnOutsider S532 # XS27
    Yup, but that'll happen in any trim S depending on the driver. Good to know though, that if I want to hypermile, I can.
  5. richkae
    richkae VIN587
    However if they add a cosmetic spoiler, it will probably hurt aerodynamics and reduce range.
    If I get the performance package, I will delete the spoiler. They are ugly on a lot of cars.
  6. AnOutsider
    But you haven't seen this one, and who knows, maybe tesla will do it right (performance, looks and efficiency). Might be a long shot, but at least wait for more info.
  7. Andrew Wolfe
    Andrew Wolfe Roadster 472 - S 440
    Los Gatos, CA
    A high-power inverter is generally slightly more efficient. (At a high cost for the added efficiency). This is die to more or better power MOSFET transistors being used.
    However, as mentioned, this assumes that the two cars are driven identically. If you use the extra performance, it will use more energy.
