204.
What do you guys think? Should I subject this brand new car to a max charge just to see where it nets out?
Yes! I'm at 193 with 20K miles after 14 months
204.
of course.. it's not even your battery, plus it looks like it's actually good for the battery (once in a while)
Also of note: The reported 100% Range of my vehicle dropped from 424 km to 400 km during the first year of operation. However, I have not seen any further decline in reported range throughout this winter. I've heard that the chemistry being used tends to drop a bit at first then level off for a long time. So far that is looking to be confirmed.
Been a while since I chimed in on anything so nice to see you all alive and kicking on here.
Just recently I noticed a drop in full charge that seems fairly significant. When I got my 60 MS the rated range was 208. About 15 months later and just over 10K miles on it, a full range charge gets me 182 miles. Pretty significant difference. I asked Tesla about this and after 4 or 5 emails it was pretty much a clown show. The ultimate answer I got consisted of instructions on how to switch from Rated to Ideal range display, which had nothing to do with my question.
I will have to try the supposed rebalancing techniques and see what happens.
Cheers
PS-Ever since the slider was available I have tried to charge to more like 60-75% for daily use. If this indeed promotes better long term battery life at the expense of short term range reduction due to poor cell balance then I should be a good test case for this theory and should see a significant improvement in trip charge max range as a result. I don't have long trips coming up soon but next time I do I will go through the recommended procedure and report back.
Cheers
204.
My rated stops at 174 and my Ideal is 204. I'm even more convinced that the rated got screwed up after the 5.6 update (not 4.5 where standard dropped from 93% to 90% where 10 miles rated disappeared. Had that not happened I would have been 184 and 204 about the same as the loaner you had.
Cheers
Cheers
90% is not 90%. On other thread, someone did the math and demonstrated the 90% tick on slider is actually 97.5%. All of which happened in a software release, so it is not apples and apples to compare "90%" charge today to "normal" charge back before the slider.
Rlang, your numbers do not seem disturbing. To me, anyway.
90% is not 90%. On other thread, someone did the math and demonstrated the 90% tick on slider is actually 87.5%. All of which happened in a software release, so it is not apples and apples to compare "90%" charge today to "normal" charge back before the slider.
Doubt it. VisibleTesla and other Tesla REST API tools report a 90% battery SOC when a 90% standard charge is selected on the slider.
Now whether the 90% SOC algorithm is very accurate or not, including or excluding battery reserves, that's another question...
well, yep. I show 250 rated @ range charge on A battery w/15 months and 13000 mi. When I do charge at any tick on slider, be it 90%, 80, 70, 60 I get less than that % of 250. Far less. That's why I can't buy balancing as the whole problem, algorithm is what I suspect has largest impact.
Well, that phenomenon is because the battery curve is non-linear. You are charging to % coulombs of charge that the battery can store, not % of maximum rated miles you can drive.
The lower the battery charge the fewer miles per coulomb (for same watt power, battery current goes up at lower voltage, current -> dQ/dt goes up, i.e stored electrons get used up faster)
