I'm a bit confused as to the OP's original post. First for whatever reason I can't see the second image (a pdf) so not sure what that's about. I noticed the following on the image that was visible.
The screen above that was provided is of a home charging set up since it says Charging and not Supercharging. The charging that previously occurred at the Nyack, NY Supercharger location, which is not an urban charger, gets up to 150kW btw. Not sure if this was the same Supercharger he expressed issues with or not.
Hard to say how long after charging had started at home that the photo was taken. Guessing not long. I would normally expect tapering since the car is already more than 50% charged. He's only added like 1 mile of range so the car would be adjusting as it starts up. But then there's the Alert.
OP did you unplug the car and replug it in as per the Alert? Maybe it's a problem with your pin connectors in the charge port. My AWD Model 3 a 9/18 build, just had service done by mobile for AC filters and condensor cleaning, and one of the Basic Limited Warranty items they performed was a replacement of my Charge Port Insulator Pins with updated parts. There was a bulletin on this. I had not had any problems with my car but it was done proactively and the tech said it was something they had seen with older Model 3s so they were just replacing them as they came in for service. Wondering if this area on your car could have been an issue and gave you the Charge Rate Reduced alert and suggestion on unplugging and replugging.
Apart from also bringing out my AWD badging (got delivery before there was sufficient supply of and didn't do the group badging when it became available) and checking the tire pressure (CA Mandate for all service appointments), they also had a bulletin to re-adjust the frunk hood latch. Mine was fine but it was something else some people experienced problems with on the early cars.
OP I see you had your mobile appointment rescheduled to a SvC. Will be interested to see what they determine the issue is with yours.
