delay pulling out home plug charger
Discussion in 'Model X' started by echin, Dec 14, 2016.
Tags:
  1. echin
    echin Member
    Los Angeles, CA
    when i charge at home, there is about a 5 second delay to removing the charger out of the car charger port... the light turns green to gray or blue (i forget) immediately after pushing the button, but i have wait a few seconds for it to finally release. is this normal?
    when i go to the superchargers, the charger can be removed instantly.
  2. habanero69
    habanero69 I Dont Need Cialis. I Drive an EV.
    FLorida
    I think so. Mine has even tried to start charging again at times. I've learned to press only ONCE on the UMC, and it usually will go to WHITE allowing me to remove. I've only done SC a few times and not payed much attention to it. Seems I press and it's ready to remove in one slight pull... :cool:
  3. echin
    echin Member
    Los Angeles, CA
    do you push and hold the button? or push the button once, let go, and wait for it to allow you to pull the charger out?
  4. BigMskiman
    BigMskiman Member
    Pleasanton, CA
    My Tesla Wall Charger @home acts the same, need to wait until color cycle happens then remove once gray color stays
