Had a AWD Model 3 for just under 2 years. Traded in for a Model Y.
Ordered 8/19.
Took delivery 9/6.
Central Ohio
Long range - MSM - White interior - Tow Hitch - FSD. VIN: 39xxx
Has the door icons on the open buttons, and the new tail lights.
I've asked Tesla to review items 2, 4, 5, 6. The rest of them I'm choosing to ignore.
Ordered 8/19.
Took delivery 9/6.
Central Ohio
- Small smudge on headliner - still need to try to clean it.
- Wind noise on driver window sometimes - might be the plastic triangle on the outside of the mirror. It's not glued well at all on the driver side - passenger side definitely glued well.
- Rear driver side door alignment is off by 3mm or so, so it looks lopsided.
- Very, very, small round ding on same door as above - Rear driver side door
- Vibration at highway speed, went back to Tesla and they balanced the tires. It's better but not perfect, they're going to look at it tomorrow.
- Steering wheel is off by about 1 or 2 degrees. Logo doesn't point straight down. When it does the car goes left.
- Hood is bulged slightly.
- Hard to tell, but hood is slightly warped near the logo.
- Hood has a residue on it, I assume it was wrapped in transport.
- Couple scuffs on the rear plastic near the tow cover.
- Two small spots on the black trim that are showing the silver metal underneath.
- 2 inch paint run under the clear code on the passenger door near the very bottom. Super hard to see, only saw it when I was applying Opti-seal. Never seen it from further than 6 inch away and I still have to search for it.
