DFC Pole Fan undercurrent/fault
Discussion in 'Roadster: Technical' started by jeremyz, Jan 9, 2017.
  1. jeremyz
    jeremyz Member
    I've been getting some random messages about DFC Pole Fan undercurrent and DFC Pole Fan Fault. Does anybody know what this is referring to or what the DFC unit is?
  2. PV-EV
    PV-EV Member
    Alaska
    Pretty sure it's PEM related. What error codes does it throw?
  3. jeremyz
    jeremyz Member
    That's what I was guessing. I will get the code the next time that it pops up.
  4. PV-EV
    PV-EV Member
    Alaska
    Dual fan controller
  5. Doug_G
    Doug_G Lead Moderator
    Ottawa, Canada
    Dual fan = the fan assembly for cooling the PEM and motor. If that fan doesn't work, you can't drive very far before the car shuts down.
    I'd contact service... you don't want to get stranded on the side of the road!
  6. jeremyz
    jeremyz Member
    I have a Roadster 1.5. I thought that the 1.5 had a single fan for cooling the PEM. I haven't noticed the motor or PEM getting hot (although it is theoretically "winter" in Texas right now). It's kind of a flaky error, so I wonder if the connector is loose or something
  7. jeremyz
    jeremyz Member
    From doing a little research, I see that I have that backwards. It's the 1.5 that has the dual fans.
  8. dhrivnak
    dhrivnak Active Member
    NE Tennessee
    Correct there is a blower for the motor underneath and a second integrated into the PEM on the drivers side.
