Did 8.0 remove side view mirror positioning while in reverse?
Discussion in 'Model S' started by RAW84, Oct 28, 2016.
Tags:
  1. RAW84
    RAW84 Member
    Boston
    I've noticed lately that my profile settings no longer have the position of my side view mirrors stored in my profile when I go in reverse. It's the same when I'm in Drive or Park. I used to have my passenger side mirror point down to the rear tire to help me avoid curb rash whilst parallel parking.
    Did 8.0 remove this feature, or is something wrong with my car?
  2. ecarfan
    ecarfan Well-Known Member
    San Mateo, CA
    Check your settings to make sure that the mirror tilt in reverse setting (Not sure of exact terminology) didn't get turned off by the V8 install. I haven't seen a report of that happening, but maybe it did.
  3. msnow
    msnow Active Member
    SoCal
    ^^ this. Mine still works.
  4. Max*
    Max* Charging
    NoVa
    Mine still works too.
  5. GaryH
    GaryH Member
    Purley, Surrey
    Ours is OK
  6. JPP
    JPP Active Member
    SF Bay Area, CA
    Sometimes with a firmware update the auto-tilt in reverse gets clobbered. As ecarfan noted, be sure the option is still on in your settings. Then park somewhere safe with your foot on the brake, go into drive and check your mirrors, then go into reverse, adjust the mirrors as you like them, go back into park. See if the mirrors all look good, then update your stored profile. All good. FWIW, the 8.x update did not bash my mirror tilt (...but lots of other stuff is suboptimal...).
  7. JohnnyG
    JohnnyG Weee!
    Columbus, OH
    Mine still works fine too. I did have two other settings that got turned off during the v8.0 update though. Always go back through all of your settings after a firmware update, just to be certain.
  8. RAW84
    RAW84 Member
    Boston
    Thanks!
    I don't remember ever setting that feature, so i didn't know it was an option. My guess is that the service center disabled it and it wasn't 8.0.
  9. trils0n
    trils0n 2013 P85
    SF Bay Area
    Also, sometimes software updates don't change the setting, but simply delete the positioning. So you'd have to preposition your mirrors while in reverse again and save driver profile.
  10. travwill
    travwill Active Member
    Chicago, IL
    I thought for this feature that it only works if you have that button selected when you go into reverse. Thus, in reverse the first time with right mirror button selected, choose how much tilt you want, etc. If you reverse again in future with the right button selected this mirror will tilt back to that preset level again. If you have left mirror selected last, then you won't see any tilt in right mirror next time for example.
  11. trils0n
    trils0n 2013 P85
    SF Bay Area
    Don't have to select buttons each time. Computer will remember settings regardless of which mirror button is lit.
    For driving mirror position (car in drive or park) set mirrors, hit save profile. In drive, mirrors will go to position they were saved.
    For reverse mirror position (car in reverse) set mirrors, hit save profile. In reverse, mirrors will go to position they were saved.
  12. FloridaGary
    FloridaGary Member
    Orlando, FL.
    This ^ After 8.0 my side mirrors didn't collapse when the door locked due to the setting being changed after the update. Also, there was one occasion that the car did not automatically lock. I do a re-boot of the car. Foot on brake and shut down vehicle entirely, especially after a major download.
