Did last sw update break bluetooth?
rjdoc74
922
692
LA, CA
My iphone 12 pro stopped connecting to bluetooth since last sw update. The phone shows "connected", but the car doesn't connect manually or automatically. It wouldn't even delete the existing "profile", it gets stuck in "please wait" forever. I tried several recents, both car and phone. Nothin. I am on 2020.44.15. Anyone else has this issue?
glide
2,773
2,759
Did you update your iPhone recently to 14.2.1? I’ve noticed some Bluetooth issues resulting from that.
rachaellewis
New Member
Nov 25, 2020
2
0
92660
I'm having similar problems and it's maddening! I'm on Samsung/Android. My phone connection consistently goes in and out every 30 seconds or so specifically since the last update. I've rebooted already. How do we find out if there's a known bug or report problems? Thanks!!
hcdavis3
HCD3
Mar 3, 2019
1,814
1,058
02571
If the phone won’t connect, try forgetting the device and re pair. When my car has been in service mode, and I get my car back my phone won’t connect. I have to forget it and re pair. After that all is good.
rjdoc74
922
692
LA, CA
I have the exact same issue. I can’t seem to get my phone reconnected and cannot delete my old phone profile. Sigh... searching the forum for a solution
Last night I was finally able to delete the old phone profile. The car found “iPhone” and pair code showed up on the phone. But it still doesn’t connect. This is so frustrating.
rjdoc74
922
692
LA, CA
no luck on my end, so I’ve scheduled a service visit. Feeling pretty old right now as I’ve scheduled a service appointment to ask for help to connect my phone. o_O
Here is my prediction: one day before your appointment you will get a text saying “this will be fixed with a future software update” and they will cancel your appointment.
RedXowner
176
96
Springfield, Virginia
I had the same issue a couple weeks ago. When I tried to call someone, the car didn't recognize who I was trying to call b/c the car wouldn't download all my contacts. This is a recent development, b/c I've used the call feature in the car many times. Not sure exactly when it started, but probably in the last month or two. I too tried Forget this Device on both the car and the iPhone 7 with OS 14.2, and the car continued to get stuck with the spinning circle trying to Forget Device. I reached a point where I was able to Forget on both the car and the phone but then couldn't pair them back again. This went on for a week, so I made a mobile service appointment. When the tech came to my house in his Model S, he couldn't get the car to work either. We went out and paired my phone with his MS, and the phone paired perfectly. Then he tried pairing his iPhone 7 to my X, and it paired but also didn't download all the contacts from his phone either. This makes it pretty clear it's not my phone and has something to do with my X. He couldn't fix the problem. He said he would have the SC do a remote diagnostic, which they did yesterday, so I was told. So this morning after getting parked at work, I Forgot both devices again, repaired, and lo and behold, all my contacts downloaded. All is back in order. Not sure if this is temporary, but it worked as of this morning.
rocketdallas
108
67
Dallas / St. Maarten
Posting a quick update on my end. All is fixed with great service from my local mobile service team. There was something wrong with the bluetooth function on my individual car, but the professional plugged into the system, erased the past entries there, and did a reflash (? sorry, I'm not very technically oriented) which did the trick. Back to normal!
Maarten
3,089
2,308
Hilversum
Exactly what a ranger did with my car yesterday.
Had the same problems.
Billing says: reflashed the parrot.
Problem is over.
Reactions: rocketdallas
