So not sure exactly how reliable it is but found a way to view green button data. This is the result.
View media item 121849
the grid draw is odd. I didn't notice that it cut off after the morning. All of the solar is going to the PW, so he has to be pulling from the grid
what is your TOU set att in the App? Wonder why you would be sendding back to the grid at 2AM
Isn't the greeen button data from SDGE?
what does Tesla app say you sent to the grid?
So tried running it backup only and a few other modes still getting some discrepancies:
10/23 - SDGE used 3.195 kWh, Tesla App From Grid 0.1 kWh, Tesla App To Grid 0.1 kWh.
10/22 - SDGE used -5.88 kWh (so net production), Tesla App From Grid 0.1 kWh, Tesla App to Grid 3.2 kWh
Emailed Tesla, is there a better way to reach support?
So are you saying that you ran in backup only mode for a full 24+ hours and your app is only reporting that you pulled 0.1kWh from the grid? That doesn’t make any sense. In backup only mode you should have pulled power from the grid the entire time the sun was down. Unless you had everything in your house turned off that should have been way more than 0.1kWh. Can you post the graphs from that time period?
Sorry those last two were trying out ToU (not on a ToU plan but just curious if it changed anything)
on 10/21 ran full backup mode SDGE - Used 18.08 kWh, Tesla App From Grid 12.2 kWh, Tesla App To Grid 2.9 kWh
Yeah, i wasn't expecting a .0001 kWh accuracy but these numbers seem noticeably different. Is it better to call or email Tesla support?Very weird. I think it’s probably worth calling tesla at this point. I wouldn’t necessarily expect the numbers to match exactly, but I would certainly expect them to be reasonably close, much closer than what you are seeing.
So just called Tesla support, they said there is a known bug in the 1.5 firmware that can cause issues like this and rolled my system back to 1.49 until the bug is fixed. Need to wait 24 hours for the firmware push to be effective but if I'm not seeing more accurate numbers in 2-3 days need to call Tesla back.
That’s interesting. Do you know if you were on 1.50 or 1.50.1? I guess if it was fixed in 1.50.1 they would have put you on that.
I’m on 1.50.1 and I just compared the data in my Tesla app to my utility over the past few days and they were all within 2 or 3%, which I think is totally acceptable. One thing I did note that I thought was kind of interesting is that some days my utility was slightly higher than the Tesla app and some days the utility was slightly lower than the Tesla app.
