Discounting the neutral connection what is the difference between a 14-50P and 14-60P if they both support 4 gauge wire? The two straight blades and the ground appear to be physically the same on both. To verify my replacement PCS board would charge at 48A, I installed a oven/range 14-50 pigtail on my version 3 Wall Connector. I know this Wall Connector was only certified for direct wiring. Seems like it should be safe with this pigtail if it were configured for a 50A circuit (40A charging)? Connected the two 6 gauge wires to the two straight blades and the 8 gauge wire to the ground lug. Plugged it into 14-50 outlet mounted on a pole at a friends house. The circuit was protected by a 50A Buss fuse. Charged at 48A for two hours while monitoring the pigtail and 14-50 connection for hot spots. I was charging at above the 80% level but the charging session was uneventful and was under four hours. Has anyone wired a pigtail using a 14-60P connector/4 gauge wires to a version 3 Wall Connector and used it as a permanent 48A charging solution? Thoughts.
