Differences in roadster versions
Discussion in 'Roadster: Technical' started by frequencydip, May 23, 2012.
  1. frequencydip
    frequencydip Sig 100 - #52
    Los Angeles
    Does anyone know what changed form version to version, i.e. 1.5 to 2.0 to 2.5? I'm looking to build a comprehensive list.
  2. vfx
    vfx Well-Known Member
    CA CA
    VIN #500 was the last 1.5
  3. Doug_G
    Doug_G Lead Moderator
    Ottawa, Canada
    Any such list won't be entirely accurate, because Tesla phased in a lot of upgrades as they became available, and in some cases retrofitted cars already on the road.
  4. TEG
    TEG Teslafanatic
    There are old threads you can find on this forum that describe most of the differences.
    The biggest change was 1.5 -> 2.0 (at VIN #501) where they switched to a new motor/PEM. You can tell those right away from the VDS in the center (instead of to the left) with the push-button direction selector (instead of "stick-shift"). That is also when they removed the tach and replaced it with the kW power meter.
    Soon afterwards they introduced the sport variant. The changes from 2.0 to 2.5 were more cosmetic. Perhaps the revised front and rear bumpers are the most noticeable... And the double DIN dashboard NAV upgrade option.
    There is a whole history of seat upgrades. And exterior color options...
  5. tennis_trs
    tennis_trs 2010 2.0 Roadster Sport
    The Sport model was available at the start of the 2.0/2010 models. #502 was a Sport:
    My New Roadster 2.0 Sport
  6. TEG
    TEG Teslafanatic
    I think that qualifies as "soon"... :smile:
  7. frequencydip
    Los Angeles
    #7 frequencydip, May 24, 2012
    Ok good so far, here are some specifics, please confirm or correct as needed:
    Early Versions
    Engineering Prototypes 5
    Validation Prototypes 17
    Version 1.5
    Founders series 27
    Signature series 100
    Production series 400
    Version 2.0 VIN#'s 501-?
    New Motor design
    New PEM design
    Introduction of Sport model
    VDS moved from left to center console
    Push button shifting replaced lever shift knob
    Replaced tach meter with kW power meter.
    Version 2.5 Vin#'s ?-2500
    Double DIN dashboard NAV upgrade option, 7" touchscreen display with back-up camera
    A new look, which includes a new front fascia with diffusing vents, and rear diffuser
    Directional forged wheels available in both silver and black
    New seats with improved comfort, larger more supportive bolsters and a new lumbar support system
    Power control hardware that enables spirited driving in exceptionally hot climates
    Improved interior sound reduction including new front fender liner material to make the cabin quieter
    PEM improvements for cooling
    Roadsters shipped by Geo
    North America 1464
    Europe 799 ???
    Asia 237 ???
  8. Doug_G
    Ottawa, Canada
    2.5 also had PEM upgrades.
  9. TEG
    TEG Teslafanatic
    I had taken a "stab" at figuring out those production numbers before.
    Mentioned here:
    Where they now? The first 100 Roadsters
  10. TEG
    TEG Teslafanatic
    I might be wrong, but I think they delivered #501 as a non-sport customer car, but held onto #502 for internal evaluation for a long while (but eventually sold it I think.)
    As I recall there was a bit of a delay between the first 2.0 customer delivery and the first "2.0 sport" delivery even though you are right that #501 is the first 2.0 and #502 is the first 2.0 sport.
  11. TEG
    TEG Teslafanatic
    I recall the transition from 2.0 to 2.5 was a little "squishy". It didn't happen at a model year changeover like 1.5->2.0 did.
    I think the 2.5's start showing up around VIN #964
    More like 964-1464 (hmm, that is exactly 500...)
    You may want to look at this posting:
    Roadster production dates
    Also, note, I dug up a lot of info (looking at Carfax and such) on North American bound Roadsters, but have very little knowledge of the European/Asia/Australia sequence. If you only talk of the last 4 digits of the VIN then there can be another (but non-North American) Roadster with a VIN that ends in the same last 4 digits.
    The European VIN -> Model feature and production count list is a bit different from what went to North America, so you would likely want to try to track them separately.
  12. tennis_trs
    I believe that "Directional forged wheels available in both silver and black" were available for at least 2.0 and maybe 1.5. I believe that the change at 2.5 was just a different design (I thought just cosmetic).
    I thought that most of the changes that improved cooling were done starting at the 2.0.
  13. augkuo
    augkuo Member
    Berkeley
    Also later versions (past 783) had a plastic trunk flocked instead of exposed carbon fiber -
  14. daniel
    daniel Active Member
    Kihei, HI
    So 1.0 was only the prototypes, and the first actual production Roadsters were 1.5? Interesting.
  15. vfx
    CA CA
    Hasn't all this been done before?
  16. doug
    doug Administrator / Head Moderator
    SF Bay Area
    Yes, hopefully TEG can add some organization.
  17. TEG
    TEG Teslafanatic
    I can try to make a summary posting consolidating these different questions, ideas, and information.
    It will take a little time though.
  18. TEG
    TEG Teslafanatic
    Some of the EPs, VPs, Founders and very early sig 100 started out with 1.0 drivetrain, but got upgraded/retrofitted with 1.5 as soon as it was available.
    The original 1.0 idea called for a 2 speed gearbox. The 1.5 "redo" switched to single speed gearbox, but a vastly improved PEM that provided enough more low end torque to make up for the loss of a lower gear.
  19. TEG
    TEG Teslafanatic
    #19 TEG, May 24, 2012
    Originally the Roadster was only offered with the silver finish forged wheel seen on the left here:
    (the black finish was mostly seen on 2.0 sports later.)
    Part way through 2008 production, they switched to a standard cast wheel as seen here:
    And they made the forged wheel optional. For a while they were delivering cars with a dark finish (as seen in the right picture above) on the cast wheel, but switched to a shinier finish (on the left) later on.
    With the 2.5s they switched the forged wheel option to a revised "pinwheel" design as seen here:
    Over time some people swapped wheels, or "mixed & matched" options so it isn't really clear to know what year or variation of Roadster will have which exact wheel.
    Generally the black wheels tend to be on sports. Generally the cast wheels tend to be on non-sports. But there are exceptions to that as well.
  20. doug
    SF Bay Area
    Actually, this was a feature of the January 2009 price increase on the 2008MY which affected cars somewhere around VIN200 through VIN500. So this was, in fact, considered the standard wheel for the majority of the 2008MY cars. As you say, the iconic forged Tesla wheels became an added cost ($2300?) option.
