Different Phone for Better Connectivity
PianoAl
855
527
Far Northern California
About 30% of the time, my car has trouble recognizing my phone (won't unlock or won't let me drive). I sometimes have to turn airplane mode on then off. Other times I just wait a minute or so.
It's the same for my wife. We both have el cheapo Tracfone Samsung Galaxy J7 Skypros, which work fine for our modest use.
Question: If I were to buy a different model, would this problem likely go away? Specifically, here the the Tracfone models I could buy—if you have one of these, please let me know about your experience with the car/phone interface. Thanks.
Galaxy A21
Galaxy A51
MOTO G Stylus (XT2115DL)
MOTO G Power (XT2041DL)
MOTO G7 Optimo (XT1955DL)
Watts_Up
3,449
2,350
In a galaxy far, far away
I think you need to isolate the problem between your car and your phone Bluetooth problem.
If you have problem with the car Bluetooth, a new phone will not solve the problem.
Do you have problem pairing your phones with your car, or is it your car not able to detect your phones after pairing?
PianoAl
855
527
Good point.
Here's why I don't think it's the car: Wife and I will be in the car, and sometimes it will recognize one phone and not the other.
They are paired fine and usually work with no problems.
PianoAl
855
527
Here's a tip when using the phone as a key, and unlocking the door (when it doesn't immediately unlock): Instead of trying, swearing, and trying again, push the door handle in and hold it. Very often, it just takes a few seconds, and if you hold it in, it will unlock as soon as it's wakened.
Also, looking at related threads, often people think they've found the solution (e.g. I need to have my phone unlocked!* I need to have the app running!*), but in reality, there's so much variability that one is fooled into thinking you've cracked the code. I fell into that trap once, reporting here that when the car won't wake up, all you need to do is lock and unlock it, and it will connect. Turned out that was just chance.
*Neither of those are true.
RTPEV
933
1,026
Durham, NC
I have found the best way to improve the reliability of the phone being recognized (after you've taken the usual measures to prevent the app from going to sleep in the phone) is to be holding the phone in your hand as you approach the car. I really only have problems when I fail to take the phone out of my pocket. And if the phone is in one's back pocket, the problem is even worse. I think the BLE signal is just not strong enough to make it through heavy clothing, and certainly not through the human body when it's between the phone and the car.
