Differentiating speakers
Discussion in 'Model S' started by Rbcnr, May 11, 2017.
Tags:
  1. Rbcnr
    Rbcnr Member
    New York
    My new MS is at the SC getting some little things fixed. I have the standard sound system. Got a new MS 90D loaner with a lot of bell and whistles - I think sound system sounds better. I think it's the ultra high fidelity sound system. Any way to tell for sure visually? Ie look for extra speakers somewhere, etc? Thanks
  2. Rbcnr
    Rbcnr Member
    New York
    My new MS is at the SC getting some little things fixed. I have the standard sound system. Got a new MS 90D loaner with a lot of bell and whistles - I think the sound system sounds better. I think it's the ultra high fidelity sound system. Any way to tell for sure visually (I don't wanna ask the SC staff)? Ie look for extra speakers somewhere, etc? Thanks
  3. Cricket88
    Cricket88 Member
    Los Angeles
    Get into the EQ settings and if there is a check mark option at the bottom center for Dolby, then it's got the high fidelity sound system
  4. AEdennis
    AEdennis Active Member
    If I remember correctly, the upgraded system has XM, so if an option for that shows up, it's upgraded. Otherwise, its standard.
  5. Tam
    Tam Active Member
    Visalia, CA
    If Model S hasn't changed its design, the subwoofer is located on right rear side corner which means you can't stuff a football or a bag there the way you can on the left rear side corner where you place your bag of adapters there.
  6. Rbcnr
    Rbcnr Member
    New York
    All glass roof - don't think you can get xm with that? Will check for Dolby and subwoofer. Thanks!
  7. Rbcnr
    Rbcnr Member
    New York
    Checked - it's the standard system. Took note of the settings. Thanks
