direction indicator sound
Discussion in 'Roadster 2008-2012' started by einhalv, Mar 20, 2020.
  1. einhalv
    einhalv Member
    Horten, Norway
    When I use the direction indicator, the lights blink but there is no sound. Is this normal for a roadster? All other cars I have driven go click, click. click ...
  2. ViperDoc
    ViperDoc Roadster 1305
    Vermont
    I am pretty sure mine goes click, but I will check tonight!
  3. drewski
    drewski Supporting Member
    SF Bay Area
    just checked. mine clicks
  4. ViperDoc
    Vermont
    mine does indeed click!
  5. Timothy
    Timothy Driving on Sunshine
    I tested mine and no click. Oh! I forgot my hearing aides!
    • Funny x 2
  6. EV-1
    EV-1 New Member
    Melbourne Aust
    Personally, I don't think the clicking sound is loud enough (no, I'm not deaf - yet).
    I think this could be something Tesla could easily address simply by giving the driver the ability to adjust the volume to the desired level in the software.
    Or, they could take it a step further and let you choose the tone or a theme like fart sounds, bullets firing or, for basketball lovers, the sound of a basketball bouncing on a court! ;) I'm sure that such things could never happen (legally) but you have to agree that the possibilities are endless, right?
    Seriously, the amount of times I have accidentally left the blinker on is ridiculous! :(
  7. jason.tv
    jason.tv Member
    Florida
    no issues here; mine is loud and I'm hard of hearing, 40% loss in my left and 30% in my right. Click is very noticeable, just as loud as a ice car if not louder.
    Perhaps it's the type of car; what year and model do you have? Perhaps something is wrong; did you ever notice it was louder in the past now it's more faint? Maybe the Service center can diagnose this for you.
    Mine is a 2011 sport 2.5
  8. CAR3NUT
    CAR3NUT Supporting Member
    Tucson, AZ
    Just drove mine to the SC and it does click...............:)
  9. einhalv
    einhalv Member
    Horten, Norway
    I expect that the sound should come through the loudspeakers and since also my handsfree microphone is not up to its task, I will have the SC look at the audio system when the car is in for its annual service in a couple of weeks. Hopefully they can both explain and fix it.
    Mine is a 2012 sport 2.5
  10. X.l.r.8
    X.l.r.8 Supporting Member
    Toronto/Miami
    You may simply have an electronic flasher.
  11. einhalv
    einhalv Member
    Horten, Norway
    Update: The service center was not able to diagnose the error on the first try. They need further diagnosis involving dash removal which we for various reasons agreed not to proceed with now. Their hypotheses for the source of the error were a speaker, the switch pack or the instrument cluster. I find the switch-pack hypothesis particularly appealing as I also have problems with charging of the 12-V battery which I believe can be attributed to the switch pack.
  12. ML Auto
    ML Auto Member
    SW Florida
    The turn signal is operated by a relay in the switchpack, which is around $1200. You might just want to live with it.
  13. einhalv
    einhalv Member
    Horten, Norway
    Yes, probably. However, the 12-V charging which I think also is controlled by the switchpack doesn't work (4.8 V at the fuse) and I do have a spare switchpack from a salvaged car. Therefore, if and when I have learned more about how the car works, verified somehow that the salvaged part is in order and summoned sufficient courage, I will consider doing it myself. It might take a while.
  14. DerbyDave
    DerbyDave Member
    Kentucky
    Make sure you don't have "Joe" mode on. In Model 3s, there were reports that this silenced the turn indicator sound. Controls > Safety & Security > Joe Mode
  15. Nvbob
    Nvbob Roadster 1256
    Just east of Lake Tahoe, Ca.
    @DerbyDave - this is a Roadster forum. We don't have no "Joe Mode".
  16. DerbyDave
    DerbyDave Member
    Kentucky
    #16 DerbyDave, Aug 30, 2020
    OMG, No "Joe" mode? :eek::)
    • Funny x 3
  17. ML Auto
    ML Auto Member
    SW Florida
    I believe the switchpack has to have the same firmware in it to work in a swap. Otherwise you will get a mismatch error. And yes, the 12V charge current does come from it.
    • Informative x 2
  18. einhalv
    einhalv Member
    Horten, Norway
    Interesting. Do you know how to access the firmware somehow? Anything from just extracting some piece of information to logging in or downloading/uploading from the switchbox would be useful.
  19. ML Auto
    ML Auto Member
    SW Florida
    In the diagnostic menu you can read the firmware versions. The switchpack is SWP
    • Informative x 2
  20. Peter.h
    Peter.h Electric Newbie
    Rancho Palos Verdes, CA
    I had a switch pack issue myself for the last six months - hi beams would not work and I would get a “check bulb” error. Tested wiring ask the way back to the switch pack and all was well.
    I ended up disconnecting the relevant wires (Feeds from fuse box, outputs to the lights, and trigger wire) at the switch pack and wiring in a couple of relays instead - that worked like a charm.
    Only issue was that it would throw an error message if hi and low are engaged at the same time - I imagine the switch pack normally disconnects the lows when highs are triggered, so I wired in a third relay to turn off the lows when the highs are triggered.
    happy to provide more details / wiring sketch if it’s helpful to someone.
    I’m hoping one day there will be someone smarter than me who figures out how to repair switch packs. Until then a handful of relays will hopefully tide me over.
