Dirty Butt
Discussion in 'Model S: Interior & Exterior' started by Cerie, Dec 2, 2014.
  1. Cerie
    Cerie Member
    Connecticut
    I've noticed now that the weather has become gloomier and the ground is covered with a mix of powdered salt and rainwater that the Model S tends to kick up a lot of that grossness onto its own backside. Is this due to its aerodynamic shape or because there is no exhaust to "blow away" the ick? Next up on features: a protective bubble surrounding my car that protects it from the outside world (think hamster wheel) but until then, weekly car washes it is!
  2. liuping
    liuping Active Member
    San Diego
    Black dusty road grime shows on my Model S's "backside" all year round here in San Diego. I think you are right about the aerodynamics.
  3. FLDarren
    FLDarren Member
    Seminole, Fl.
    That's usually the dirtiest part of my car besides behind the tires. I have the LED license plate bulbs and they really let the dirt show at night.
  4. JakeP
    JakeP S P4996 / X P6028
    Wexford, PA
    I use a California Car Duster to keep that back end clean, it is amazing how much dust adheres back there. A combination of airflow and electrostatic adhesion, I would wager.
  5. Newscutter
    Newscutter Member
    Wexford, Pennsylvania, United States
    Even more interesting (to me) is how CRISPLY the road grit will deposit itself on the trailing edges-- like pin striping!
    See pic (I can't get it to embed)
    Tesla Pittsburgh on Twitter:
  6. Todd Burch
    Todd Burch Electron Pilot
    Smithfield, VA
    A little aerodynamics:
    Ironically, a more aerodynamic back side should lead to less dirt on the tail, since better aerodynamics would imply less of a pressure drop immediately behind the car, which in turn would have less of a vacuum effect to suck grime onto the tail.
    However, having said that there are a few factors:
    1) Yes, the shape of the rear seems to cause air patterns that tend to pull dirt up off the road and onto the tail. All Model S's are subject to this. (It's ok...AFAIK we still can claim the lowest drag coefficient of any production car).
    2) The smooth underbelly of the car causes more laminar (smooth) flow underneath, as opposed to an ICE which causes more turbulent flow. This yields better aerodynamics, but may also contribute to the "coordinated" lifting of grime from the roadway.
    3) A possible contributing factor: The high torque produced at low speeds coupled with the lack of mud flaps may fling more grime up, and since this happens at low speeds, there is less surrounding airflow to blow the grime away from the car.
  7. JakeP
    Wexford, PA
    Oh I like the laminar flow explanation, that makes good sense.
  8. Todd Burch
    Smithfield, VA
    Update: Paying more attention to the geometry of the body around the rear wheels, I'd say my theory in #3 above is an unlikely contributing factor--so #1 and #2 seem to be the primary causes.
  9. RiverBrick
    RiverBrick Active Member
    Québec
    #9 RiverBrick, Dec 2, 2014
    Even considering the RWD?
    When driving over snow, the license plate can quickly become blotted out. I'd rather not get stopped for a warning for this. Is there a more convenient solution than frequent cleaning stops?
    Just in case someone's not familiar with the phenomenon, here's an image lifted from the Cross Country Rally video.
  10. ecarfan
    ecarfan Well-Known Member
    San Mateo, CA
    I think every car I've owned has attracted more dirt at the rear than the front. I know my Roadster, Porsche Cayman, Porsche 356A, Toyota Prius, Subaru Forester, Mini Cooper and Ford Merkur all have displayed that characteristic. The Model S seems typical in that regard.
  11. Barry
    Barry Active Member
    Colorado
    They make automotive toilet paper for that :smile:
  12. JakeP
    Wexford, PA
    What are your thoughts on electrostatic influence? The motor and drive train are within inches of that rear cowling, and I know they are magnetically shielded, but I still can't help but think this is a contributing factor. The way that back end is a dust magnet just makes me think "static cling"!
  13. Todd Burch
    Smithfield, VA
    Interesting thought, but I doubt that plays any factor.
  14. green1
    green1 Active Member
    Calgary, Alberta, Canada
    I'm with ecarfan on this one... show me a car that DOESN'T have this issue. I've never seen one.
  15. liuping
    San Diego
    You could be right, it may just be more noticeable to me since this is my first white car.
  16. ecarfan
    San Mateo, CA
    @liuping, four of the seven cars I listed in my post were white or very close to it, and I certainly noticed the greater amount of road grime in the rear compared to the front. I always wash my cars myself, I never take them to a car wash, so I do take note of where the dirt is.
  17. ecarfan
    San Mateo, CA
    (Deleted, inadvertent duplicate post, sorry)
  18. mknox
    mknox Well-Known Member
    Toronto, ON
    Yes, but it is definitely worse on the Model S than anything else I've driven. Not really an issue except that it really interferes with the rear view camera. Even if I wipe it off, it's blocked again within a few miles on salty/wet winter roads.
  19. Cerie
    Cerie Member
    Connecticut
    I didn't mean that this is the first car I've had where the back gets dirty but all my other ICE cars have gotten dirty near the sides or the bottom bumper. I just noticed that the Model S tends to really KICK that dirt up all the way up to what would be the trunk part of a non hatchback.
  20. green1
    There are really only 2 solutions to help keep the back of a car clean.
    1) mud flaps. The bigger the better.
    2) wind deflectors, you see these occasionally on station wagons, mini-vans, and SUVs, most are useless, but some direct air down the back just right to keep it clean.
