Disable stability control without disabling ABS?
Discussion in 'Model 3: Driving Dynamics' started by jamnmon66, Jul 12, 2018.
  1. jamnmon66
    jamnmon66 Member
    Brighton, CO
  2. Funkmobile
    Funkmobile Member
    Vancouver
  3. AltLogic
    AltLogic Member
    SoCal
    I was under the impression that he uses a stand alone ecu to help control the motor.
  4. Skysurfer
    Skysurfer Member
    Iowa
    That was for his Lotus project which he grafted a Model S motor into.
  5. Knightshade
    Knightshade Active Member
    NC
    Do you mean an ABS sensor? I can't imagine why a tire pressure sensor would have anything to do with any stability control systems.
  6. Funkmobile
    Funkmobile Member
    Vancouver
    I’ll have to dig up the sources again but I believe if you unplug the ABS the power steering goes as well. I think that was from a YouTube vid highlighting the upcoming mountain pass performance mods.
    I believe the TPMS bit was from a comment on that video.
  7. MP3Mike
    MP3Mike Well-Known Member
    Oregon
    @MountainPass Are you going to be releasing something to dial back the stability control for other people purchase? What is it going to take? Hardware install, sensor change, etc.?
  8. MountainPass
    MountainPass Vendor
    Toronto, Canada
    Hey guys,
    We are working on a module right now that will plug in and allow you to fault the stability control system with the flip of a switch. The system would then revert back to normal operation upon reset of the drive unit (parking and opening the charge door for example).
    Traction control will still be active with this method, but with the stability control off you can get fully sideways as long as you do it without power :)
  9. jamnmon66
    jamnmon66 Member
    Brighton, CO
    Sweet! Thanks. Looking forward to seeing pricing.
  10. Mrmcthrill
    Mrmcthrill New Member
    Toronto
    @MountainPass
    I love what you guys are doing.
    I can't wait for that module. I did an autocross recently and would have loved to have that tool.
    Any ETA on when it will be available for sale?
  11. scottm
    scottm Active Member
    Canada
    There's probably a sensor (gyro / acceleromoter ) or a fuse you can pull to defeat stability and leave ABS intact.
    Stability sensors are usually found near the center line going down the middle of the car, under dash.
  12. ScottStout
    ScottStout Member
    Houston, TX
  13. MountainPass
    MountainPass Vendor
    Toronto, Canada
    Yes, we are sourcing OEM connectors to ensure plug and play compatibility.
  14. jamnmon66
    jamnmon66 Member
    Brighton, CO
    No fuses in this car. The accelerometer(s) is(are) probably integrated into a circuit board somewhere but maybe I'm wrong. Sounds like Mountain Pass will have some good news for us soon.
  15. ℬête Noire
    ℬête Noire Active Member
    TX
    Is it [currently?] RWD only or has it also been tested and confirmed working-as-designed on the non-P AWD?
  16. MountainPass
    MountainPass Vendor
    Toronto, Canada
    Confirmed working on all models, including P3D+
  17. ℬête Noire
    TX
    Nice. Has pricing been finalized or are you waiting on completing all the parts sourcing to commit on that? Are you ready to talk ballpark on the price?
  18. MountainPass
    MountainPass Vendor
    Toronto, Canada
    Still working on these OEM connectors, we found one very close and have inquired about minor changes to the keying. We aren't interested in having to modify every connector we sell!
  19. AllenTech
    AllenTech Member
    Bakersfield, CA
  20. insaneoctane
    insaneoctane Active Member
    Southern California
    What if I want to disable traction control but leave stability control??
