Disconnect switch for HPWC install
Discussion in 'Model S: Battery & Charging' started by Cosmacelf, Jan 15, 2016.
  1. Cosmacelf
    Cosmacelf Well-Known Member
    San Diego
    #1 Cosmacelf, Jan 15, 2016
  2. Lloyd
    Lloyd Well-Known Member
    San Luis Obispo, CA
    In most areas, the cutoff switch can be the circuit breaker if it is in sight and a reasonable distance. I used the Hubbel unit.
  3. Cosmacelf
    San Diego
    Yeah, I was looking for a disconnect that could be flush mounted, and the one I posted is the only one I've found. Although that Hubbell one looks nice.
  4. FlasherZ
    Yes, it will work. The only requirement is that it be readily accessible ("capable of being reached quickly for operation, renewal or inspection"), have a provision to lock the disconnect in the "off" position, and that the means to lock it is not removable when the lock isn't present. That locking tang will suffice.
  5. bhzmark
    bhzmark Active Member
    In some jurisdic5ions a lock out at the distant panel is sufficent also. That is you can lock the breaker off and work onthe hpwc with no fear that someone will turnit back on. Much more elegant.
  6. chriSharek
    chriSharek Member
    Sarasota, FL
    Pretty sure the National Electric Code says that if the breaker box is in line of sight, no disconnect is needed.
    I would go so far to venture a guess (just a guess) that residential installations do not require a local-cut off as everything must go through the main panel.
  7. FlasherZ
    Here is what the code actually says - and you can see why it's subject to interpretation. From NEC 2014:
    For reference, 110.25 is the standard "lockable open", which says:
    So the issue hinges on the definition and interpretation of "readily accessible". Here's the official definition, from article 100:
    Clear as mud, isn't it?
    Now, a guideline is present in the appliances article, if you're trying to convince your inspector - this was updated for the 2014 code:
    So the intention appears to be preventing energizing the circuit while the appliance is being maintained. The EV article doesn't contain the same provision but I've seen it successfully argued this way.
    Some inspectors consider having to go through a home to a breaker panel located elsewhere as the equivalent of an obstacle and want it in the same room or within line of sight - even if lockable. Some inspectors are just fine with a breaker elsewhere, provided it's lockable. Some are fine with "readily accessible" being located at 7' off the floor, some want it 6'4" or lower in line with the "highest breaker" mandate.
    Want to be safe from red-tag inspection failures? Install one next to the device.
  8. Shaggy
    Shaggy Member
    Austin
    For my general purpose slow L2 charger, I went low rent with a properly rated switch next to it.
  9. davewill
    davewill Active Member
    San Diego, CA, US
    The plug itself counts as a cutoff in that scenario. You didn't actually need the switch.
  10. miimura
    miimura Well-Known Member
    Los Altos, CA
    In addition, if it's under 60 amps it doesn't need a disconnect. The one strange rule I found out about when I installed my Leviton is that a plug-in EVSE must be removable without tools. That is why the Leviton unit pictured above has a knurled knob screw that allows you to pull the unit off the wall without tools. I didn't want to pay for the bracket kit for my EVB40, so I just used lag screws to attach it to the wall.
  11. davewill
    San Diego, CA, US
    Odd, my Blink has a plug, but definitely needs tools to dismount from the wall.
  12. Joelc
    Joelc Member
    San Mateo, CA
    Liked your setup so hope you don't mind I did something similar. :)
    Although had to install mine outside since I primarily park in the driveway. It's on the side of the garage and the sub-panel is almost directly behind the HPWC on the inside of the garage. We are in the middle of a remodel so was able to get the charger and disconnect installed without any visable conduit.
    Tesla HPWC and disconnect
    on Flickr
  13. Lloyd
    San Luis Obispo, CA
    Nice! Don't mind at all. Now you just need a neat way to hang the cord!
  14. bhzmark
    This lockable disconnect -- just a piece of metal to which you can lock the breaker open, on the breaker panel in the basement far from the HPWC was fine for my inspector. Far more elegant and cheaper than a big ugly box near the HPWC.
  15. Falcon_Heavy
    Falcon_Heavy Member
    New Jersey
    Reviving this old thread. I am in the process of installing the 90Amp circuit/HPWC. My township inspector also recommend same option (padlock circuit breaker) instead of ugly disconnect switch near HPWC. Is there any reason to install the "disconnect switch" if township insepctor is happy without it (infect its his recommendation to avoid ugly disconnect)?
  16. davewill
    San Diego, CA, US
    If the inspector is happy, I think that's all that really matters.
  17. David.85D
    David.85D Active Member
    My local jurisdiction required a local cut-off for a HPWC I had installed on the side of the garage.
  18. Falcon_Heavy
    Falcon_Heavy Member
    New Jersey
    It all depends upon the local township & inspector's requirement. for my township, a padlock on the breaker in main panel is enough instead of line of sight cut-off.
  19. David.85D
    A0B64BB6-8AAD-454E-96AC-21C8D0DAF6EC.jpeg F0DB0719-C1E4-4DA6-84F3-E3CB74549581.jpeg Just so people see. This is what the Tesla recommended electrician did. Pretty picky local jurisdiction as well.
  20. Falcon_Heavy
    Falcon_Heavy Member
    New Jersey
    I also bought similar "disconnect breaker box" from Lowes which I returned after talking to township inspector. The purpose of disconnect is to avoid shock while working on the unit and someone accidentally turn ON the breaker. Little padlock on the breaker achieve same purpose for residential use with single main panel.
    But, I agree with you, local disconnect is certainly required by many townships. The lockable means is must have by code for circuit > 60 Amp.
