H2 is only used for ullage, right? That’s a pretty big tank.And it's H2
I need to correct my error, and apologize: Helium gas (He) is used for ullage, not Hydrogen gas (H2). This article mentions that: Falcon 9 rocket explosion traced to upper stage helium system – Spaceflight NowH2 is only used for ullage, right?
I imagine they're left over from the Apollo and shuttle eras. There's no hydrogen in the Falcon 9 that I'm aware of.I need to correct my error, and apologize: Helium gas (He) is used for ullage, not Hydrogen gas (H2). This article mentions that: Falcon 9 rocket explosion traced to upper stage helium system – Spaceflight Now
Quote: “The Falcon 9 rocket’s upper stage liquid oxygen tank contains several composite helium vessels, each pressurized to about 5,500 pounds per square inch in flight. The helium is routed through the second stage’s Merlin engine, where the helium warms up and is injected into the rocket’s propellant tanks to pressurize the stage as the launcher burns fuel, keeping the tanks structurally sound.”
So...what is the liquid Hydrogen in that storage tank used for?
Good point. I may well have made a fundamental error in assuming that the tank pictured contained something. Perhaps it is simply empty.I imagine they're left over from the Apollo and shuttle eras. There's no hydrogen in the Falcon 9 that I'm aware of.
That quote explains pressurization of LOX tank. Ullage means some trust to settle propellants in the tanks so that pumps can be turned on.I need to correct my error, and apologize: Helium gas (He) is used for ullage, not Hydrogen gas (H2). This article mentions that: Falcon 9 rocket explosion traced to upper stage helium system – Spaceflight Now
Partial job description of FH pad workers. We pick very large things up and put them down.
Time-lapse video: Falcon Heavy lowered after launch pad debut – Spaceflight Now
And as the fuel for the main engines.This seems like a very sensible approach to handling these launchers. Building them vertically no doubt has some advantages, but when you actually have to work on the thing, lying it down must make everything a heck of a lot easier.
Shuttle used hydrogen fuel cells for electrical power.
I don't know if there is any 'liquid Hydrogen' but I remember reading that there are three tanks.So...what is the liquid Hydrogen in that storage tank used for?
There are many tanks holding different stuff.I don't know if there is any 'liquid Hydrogen' but I remember reading that there are three tanks.
Two are used for the propulsion, and
the third tank is used to send pressure in the two other tanks to keep a constant pressure
allowing for a constant flow of delivery especially when the tanks start to be empty.
I will try to verify this information, but I might be completely wrong...
They used to use hydraulic fluid for the landing gear and grid fins, but I'm not sure if they went away from that; maybe Nitrogen is used now.
The main body of the first stage booster doesn't have "tanks"; rather the skin of the booster itself is the tank. It's divided into two pieces, with the smaller bottom section holding cooled kerosene (RP1), and the larger upper section holding supercooled liquid Oxygen
