I did notice a side benefit of the new Battmobile battery - I have an aftermarket AMP from LH - and I noticed a significantly increased performance from the audio, now when I play it on 5 - 6 on the volume control it is similar to when I played at 7-8 on the volume control on the old battery. Also the "sub punch" is so much more pronounced, so much so that I had to turn it down to 3 when before I was on 4.5. I suspect the old battery was almost done, but I believe the LiFePO battery has a deeper reservoir of AMPS that the Amplifier is now taking advantage of... makes complete sense - now if I could just run a heavier gauge power wire direct to the factory AMP, it would be even more powerful....
